need some advice
2.9._ranger
33
texas
ford ranger
i am making a custom exhaust system for my 89 2.9 i'm going to make a true dual system. i need some suggestions for mufflers, i want it to sound nice but not be super loud because its a v6, i also want to include an x or h pipe. i need some recommendations on what i should include in my system. im open to anything just lmk what yall think i should include
2.9._ranger
33
texas
ford ranger
i plan to make 3 to 1 long tube headers to produce better low end torque and give it better flow and sound if yall think i should do something different lmk
Junk Collector
Truck of Month
5,610
Rapid City SD
Single exhaust with stock manifolds, high flow cat and a Flowmaster or knockoff sounds pretty good IMO. That's what I have on my Explorer and my stepside truck. This is the knockoff that I used, it is literally identical to Flowmaster without their name stamped on it:
I think X pipes and H pipes and headers and all that junk is pointless on a stock or close to stock 2.9. If there are ANY horsepower gains, they will be minimal, and the benefits do not outweigh the cost. Just my opinion. A dyno test could change my mind.
2.9._ranger
33
texas
ford ranger
Main reason i wanted to do headers was because my stock manifolds are basically done for but i might take your advice tbh because I plan to engine swap so there may be no point in building a whole custom system I could probably just build off of the original manifolds to save money because they’re all that’s left of my exhaust rn
2.9._ranger
33
texas
ford ranger
Also if you don’t mind do you have a video of either of your trucks so I can hear what they sound like?
gaz
761
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
@2.9._ranger ,
• If you want max torque, long tube headers are the wrong solution, Shorty's are better for low RPM torque.
• for a true dual stock 2.9l, I can only recommend dual 2" tubing (same size as the stock manifold exhaust tubing). You do not need a special"H" or "X", you can simply separate the KKK eft and right sides
• the simplest way to cross connect is to use a cross connect muffler. Borla makes a dual in,dual out in their ProXs line; they are not loud. Very quiet at idle and at speed, the only time I hear them is deep I the throttle...and still very subtle. They are well made, stainless steel only and not too pricy.
PICS:
Stock manifold exhaust tubing (89-94 style) has been separated and is hanging loose, ready for cats.
gaz
761
Wa, Bremerton 98310
@2.9._ranger
I believe that a stock 2.9l with true dual 2" tubing will sound very close to this video using Borla ProXs.
2.9._ranger
33
texas
ford ranger
@2.9._ranger
If I were to make shorty headers how long would they be from flange to connector and do you think I could build them using the flange from a stock manifold
superj
3,588
corpus christi, texas
ranger edge
182 ci of tire shredding power
2, so far
235s
drives a stick shift ranger
Also, spintech makes nice sounding exhaust too. I have one of their mufflers on my titan and it sounds very close to stock volume, but deep. You go to their website and design the muffler from choices, depening on the sound you want and then they build it. And you can add a vibrant resonator, which really gets rid of that honda bumblebee sound
gaz
761
Wa, Bremerton 98310
@2.9._ranger
I am not a great welder but you can use a set of these, they are for the 98+ OHV 4.0l and they will bolt up like money.
Dorman PART#
674-379, drivery
674-378, passenger's
gaz
761
Wa, Bremerton 98310
@2.9._ranger ,
This pic shows flange and tubing size relationship of stock driver's side exhaust manifold compared to driver's side JBA 2.9l header (pictured stock manifold is actually 94 spec 4.0, but it is the same as 2.9 except for port size and shape)
2.9._ranger
33
texas
ford ranger
@2.9._ranger
Dorman PART#
674-379, drivery
So I should take these and continue off of them to make the dual 2”?
gaz
761
Wa, Bremerton 98310
Those are stock manifolds, they do offer an improved design over what was offered with the 2.9l but ido not know that they will outflow the stock 2.9l exhaust manifold... I'm ordered a set last week and am going to compare the results.
Yes, I feel that you should just run 2" from the manifolds...unless you are set on headers. If you are, then perhaps look at all the headers available for the;
98+OHV 4.0l engine (NOT THE SOHC 4.0L)
gaz
761
Wa, Bremerton 98310
If you do decide to use those 98+ OHV 4.0l Dorman exhaust manifolds, the driver's side is set up for EGR, you will need to plug that for 89, 2.9l.
2.9._ranger
33
texas
ford ranger
Okay I think I’ll go with the manifolds and plug the egr thanks for all the help
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
