- Aug 7, 2007
- 536
- Costa Mesa, CA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
On my way to Kansas from CA my M50D transmission began popping out of 5th gear so much, I had the drive most of the way in 4th. My brother is a professional mechanic and has his own shop in Kansas. We dropped the transmission and opened it up to have a look. We can find nothing wrong but have just looked at it with the top and back end off. We did find a lot of very small pieces of what appears to be hard plastic that is black and kind of greenish that was trapped behind the beige plastic cap that is over the nut at the back end of the countershaft. We have no idea of what it could be.
There was also a fair amount of very fine metal on the drain plug magnet. The transmission was gone though about a year ago by a recommended transmission shop. They replaced the 5th/reverse cluster as well as all the bearings and seals. It was working fine until now.
My brother is not a specialist on the M50D but knows transmissions fairly well. He is baffled at what it could be. We could take it further apart but not sure what to look for.
We found detents on the shift rods for 1st, 2nd, 3rd and 4th, but no detents on the 5th/reverse shift rod. The lever for the 5th/reverse cluster snap into 5th and reverse and seem to be held there firmly. What is odd is when the transmission was in the vehicle the shift lever seem to have a lot of play back and forth when in 5th. Gears 1 though 4 did not display this looseness. What is the mechanism that holds 5th in gear? What would cause it to pop out of gear?
I plan to be in Kansas for a little over a week, but need to get this resolve soon. Please help if you have any ideas what to look for.
Information on my truck is in my signature.
