• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
need help with engine balance
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
i am doing a 347 stroker for my swap, my machine just called 50 oz balance is not going to work/recomended. where can i get a 28 oz balancer and flywheel for manual transmission, either m5odr2 or t5? havent got transmission yet
Rock Auto 5% Discount Code: 80CBDBD15DC160 Expires: January 4th, 2021
snoranger
Forum Moderator
ASE Certified Tech
4,311
Jackson, NJ
'79,'94,'02,'17
All Fords
What accessory drive are you using?
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
98 expo, have complete donor vehicle
snoranger
Forum Moderator
ASE Certified Tech
4,311
Jackson, NJ
'79,'94,'02,'17
All Fords
351w from a 96 Bronco, 96-97 f250+, than put a 94-95 Cobra drive pulley on it. Good luck finding them.
There’s a company that makes a 28oz pulley for the Explorer setup (for 347s or 351 swaps), but I don’t remember the name.
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
i think i just found an old thread of yours on serius explorations from 2011 regarding this topic:
If you can find the balancer I posted pics of, you can just press the 4 tooth wheel off and press a 36-1 wheel on.(In the right location, of coarse.) That will give you a 28oz balancer set up for a 351 or a 347 stroker for DIS. The part number is F6TZ-6312-JA."
what about: PIONEER 872032
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
scratch all that. call damperdudes. ill have 1 next week
snoranger
Forum Moderator
ASE Certified Tech
4,311
Jackson, NJ
'79,'94,'02,'17
All Fords
Yeah, that was me. I still have that balancer and pulley.
I knew there was someone making them now, I just couldn’t remember who.
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
just need flywheel now, should be easier
Daniel Black
Active member
33
Leicester, NC
302
205/60R15 & 225/60R15
For the flywheel you'll need to decide on a transmission. The V8 T-5 bellhousing is set up for 157 tooth flywheel but the M5OD uses a164 tooth flywheel.
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
Nice daniel, I thought both were 164
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
I don't know, I was looking at a xtreme performance m5, but holy bank account. T5 I don't like moving shifter back. @Ramcharger90 your build similar to mine, t5 or m5odr2 better driver? BTW I ordered cam springs etc today
Junglejoe
Active member
29
Columbia Missouri
6.0
Here is what you want.. they have a "stock" 28 oz balancer..
Then they have this..they said it will.handle 6500 rpm
with ease
Ramcharger90
Well-known member
1,043
N/A na
306, Bcam,
T5..... but I speed shift and run the RPMs out alot and race light to light.
2drxploder
Active member
34
usa
ranger
2.5 (4 Cylinder)
stock
235 on 15s
ya junglejoe thats the one i ordered, how that clutch working ram? your hyd setup?
