Need help with brake lights !
San Antonio , Tx
Ford ranger
Recently I bought , 93 ranger 2.3L manual , so out of curiosity I started messing with the third brake light cause it wasn’t turning on so while doing that I realized my break lights don’t turn on when pressing on the brake pedal , unless I turn on the light switch . So I changed the fuse for the cargo lights and the brake lights fuse ,now only the third brake light turns on and the driver side lights when pressing the brake pedal , but they turn on ONLY with the switch . Any ideas on what it could be ?
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
Well-known member
1,630
You will need to test cab fuse panel, previous owner may have changed things there or at the engine fuse box
The 1993 brake light fuse, #10, should have power all the time, not key on or off, or light switch on or off
Fuse #10 also powers Parking lights but thru the main light switch
So main light switch may be "back feeding" 12v to fuse #10 when its on, which shouldn't happen
The light green wire from brake pedal switch splits in the cab and runs to 3rd brake light and then one wire to the drivers side rear of vehicle where it splits to the 2 rear brake lights, if only passenger side rear brake light doesn't work then could be burned out bulb or bad split at the rear
People often splice in to these wires for trailer lights, and that will cause issues as the years pass and wires corrode
So test if fuse #10 has 12volts full time
Uncle Gump
Forum Moderator
2,239
Plano IL
Lead, Follow or get out of my way
Brake lights should be hot at all times. So... work independently from the headlight switch. That part doesn't make sense. Do you have a wiring diagram? I think the Tech Library may have that one.
Being it's new to you... I would start by asking.... does it have add on trailer wiring? If so.... get in there and ensure it's not all jenky... and use a meter to check the bulbs and inspect the light sockets.
Uncle Gump
Forum Moderator
2,239
Plano IL
and Ron has the schematic covered.
San Antonio , Tx
Ford ranger
Thank you ! I will check that first and if anything I’ll come back with updates
Well-known member
1,630
There should be a 40amp fuse in the ENGINE BAY fuse box that feeds 12v to fuse 10 in cab fuse box, as said full time
franklin2
Active member
142
Virginia
This year and model must have rear amber turnsignals? If it has regular red rear turnsignals, the brake light signal runs through the turnsignal switch. I know rangers and explorers are bad for some models having amber rear turns and some do not.
San Antonio , Tx
Ford ranger
H
hmmm it has mainly red and like 1/4 of amber lights . If that makes sense
Well-known member
1,630
Rangers used separate turn signal bulb in the rear thru 1999, brake light wire was not connected thru turn signal stalk
Called a 3 wire system
In 2000(and up) Rangers, the brake light wire ran to turn signal stalk(multi-function switch) and shared the turn signal wire that runs to each rear turn signal, so 1 bulb for turn and brake on each side
So with no turn signal on both rear brake lights come on steady
If a turn signal was activated then that rear side would flash as normal, if brakes were applied then the other side would come on steady, but turn signal would keep flashing, so no brake light on that side
The 3rd high brake light is not part of this its just on or off
Called a 2 wire system
This can come into play when you hook up a trailer, there are converters/adapters you can use to adapt 2 wire to 3 wire or visa versa
franklin2
Active member
142
Virginia
Both my 84 BII and my 1986 ranger have the solid red lights in the back. The reason I asked. I seem to remember when they did switch over to ambers it wasn't a clean swap. Some models had the rear ambers, some kept the solid red.
Sounds like you have the rear amber turns. Usually a problem with the rear lights popping up with you mess with the running lights is a ground problem at the rear light. I would pull the bulbs and scrape the sockets and bulbs clean.
sgtsandman
Aircraft Tank Diver
Forum Moderator
1,776
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
I sniff fuel for a living. Don't judge me!
I would do like frankin recommends and work your way forward. If the bulbs look good, is their power at the lights? The brake pedal will need to be depressed for this.
If there is not, look for bad wiring or a trailer pick tail being wired into it other than by the spare tire pan. If there is no pig tail but there is a trailer harness plugged in by the spare pan, try removing that. Do lights have power now or do they work? Chase they system up to the front as much as you can. If the wire loom is intact and not tampered with, it is probably good.
The other gentlemen gave you info on the system and some recommendations. Like suggested before, check the fuse in the engine bay first. If that fuse is bad, there is no point checking the lights until you can get power back to the lights .
91stranger
Well-known member
461
Gets Mo Chicks
Could have the wrong bulbs in period. If it calls for a dual filament bulb and you only have a single in it then the brake lights may not turn on. Check the bulb number before you spend hours tracing wires lol. Could be as simple as getting the right bulbs.
San Antonio , Tx
Ford ranger
Thank y’all , so I found out there was like one fuse missing in the fuse box outside , replaced like 5 fuses from the inside and then I was not informed every light bulb has it’s own socket place so the reason why the passenger brake wasn’t turning on either was cause of the light bulbs and the reason why they weren’t turning while stepping on the brake pedal was cause of blown and a missing fuse . I really did stressed my self out lol and even my abs light stopped flashing , now it’s on without the flashing but I think it’s the speed sensor . But other than that everything started working fine !! Thank y’all !!!!
San Antonio , Tx
Ford ranger
Soooooo Damn right lol . But fuses as well . Little pains in the ass
