need help with 99 ranger fuel system
FORD2011
ann arbor michigan
3.0 flex fuel...71 351 W
i am putting a 99 4.0 sohc from an explorer into my 99 3.0 ranger. i believe the swap will be pretty simple the only problem i see is fuel pressures the sohc runs a 65-75 psi where my 3.0 runs at 30-40 how could i increase my fuel pressure can i just change the regulator? will the entire explorer pump assembly fit in my tank? need help!!!
A pump from an 01 Ranger would be my first attempt. Even it you just install a pump onto the exsisting sending unit.
FORD2011
ann arbor michigan
is the regulator in that assembly, swapping the pump wouldnt do much if i still had the 3.0 regulator, i might just get the entire tank system for a 01 sohc ranger.
FORD2011
ann arbor michigan
will an 01 fuel pump assembly fit in my gas tank? or would a 99 explorer fuel pump assembly fit in my tank. its looking to me like they changed the design in 01 so an 01 pump might not fit in my tank
Kirby N.
March Truck of The Month
