Need help with 94 ranger wont stay running.
alwaysFlOoReD
5,680
Airdrie, Alberta, Canada
’97, '06
Pontiac, Dodge
2.2,5.7
I believe spec pressure for 94 is 40psi. 30 psi should run. But if the volume isn't there....
pentode
Well Known Cheapskate
788
Moncton NB
There are diagnostics you can do to determine if the regulator is the problem. Step one if the pump is running is to check pressure at the rail.
I'll be happy to run through the rest either before or after you replace the regulator. Good luck!
Rick W
October Truck of The Month
25th Anniversary Merch
