Need help for odd problem
notrun58
High Plains, Colo
Hi New to this site. I have a 97 Ranger 4x4 4.0 Automatic Parked it one day running fine. The next day runs terrible.
Running a key on/engine running test shows all o2 sensor readings at 0.0000 volt. All fuel trims are at -100.0 and never changes. I get 10-11 mpg.But it never shows trouble codes. it spits and pops and bucks when cold and is gutless at all times. But no codes.
Fuse isnt blown. Wiring I can get to looks OK. Dont know what to try next. Any ideas would be greatly appreciated
SenorNoob
TRS 25th Anniversary
1,448
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I can't see how all O2 sensors read 0v unless something wrong with wring or ECU. Also with that you should have codes. Makes me think the ECU is problematic.
notrun58
High Plains, Colo
Should have put in that I replaced the ecu. No change
SenorNoob
1,448
Middle Tennessee
245-70-R16
In that case, what does your wiring look like. Any chance a connector underhood has come unplugged?
notrun58
High Plains, Colo
Not that I've been abkle to spot. Working outside and we've had snoww on the ground for awhile. Cant see anything underhood coming loose so I'm gonna climb under and try to follow wiring to O2 sensors. Strange it showed up while parked overnight.
19Walt93
4,903
Canaan,NH
351
3"
235/55R16
Might be worth checking the O2 grounds.
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
