need assistance finding a part!!!
bruceleeroy
Law Enforcement
tennessee
1983 ford range
1983 ford range
just joined because i have a serious issue finding a part for my 1983 ford ranger. the slave cylinder is held on by a clip retainer that i have apparently lost and no one, not even ford knows it ever existed. anyone have a clue? i will attach picks. 931-seven seven seven-9830
franklin2
1,498
Virginia
Will this work? It says it will fit a 1984 and I know a 1984 has the same type external slave.
Josh B
1,743
Oklahoma
Tried any baling wire?
bruceleeroy
Law Enforcement
tennessee
1983 ford range
1983 ford range
thats all i could find as well but that part is made for a transmission that has a stamped steel slave cylinder mount bolted to the side of the bell housing opposed to a cast in place like mine, besides that looks more like a bushing. i cant imagine that they rely only on the plastic cover to hold this thing in place....that is 40 years old and driy rotted and cracked and i cant find for sale anywhere
bruceleeroy
Law Enforcement
tennessee
1983 ford range
1983 ford range
well if i was on the rd stranded yes, but after rebuilding an engine wanting to put it into regular service i would like a better plan z if possible before resorting to mcgyver and ductape....tho bailing wire is a nice piece of kit.
Josh B
1,743
Oklahoma
Hey man, you gotta do what you gotta do.
My mom was coming in from town once on the old dirt route and the muffler came loose. A neighbor came along as she was untying some baling wire from the bumper to use on the muffler
Josh B
1,743
Oklahoma
Have you got any access to old stock at a wrecking yard or something like that?
Man, our wrecking yards are being shipped to China who is using them to build battleships
bobbywalter
TRS Technical Staff
4,094
woodhaven mi
FORD mostly
BIGGER
sawzall?
i would be tempted to bolt on a d 50 unit....but most likely would just make a shim out of some strap and drill two holes to retain it with a 3/16 cotter key.
franklin2
1,498
Virginia
You can really back yourself in a corner messing with those early trucks. They were oddballs with that 2.8 engine and external slave. Not so much the engine though, I did convert mine over to a mitsubishi 5 speed, and it all bolted to the 2.8 with a internal slave and the different flywheel. I was going to rebuilt the original toyo koyo 5 speed, but that is another odd duck that is hard to find parts for. Once you get into the little bit later trucks, everything smooths out a little bit as far as transmission setups. And they all bolt to the 2.8 with no problems.
