Need advice for drilling out door lock
20karatferret
Norfolk va
Ford ranger
I have a 2001 2.3l ford ranger with no key. I'm trying to save money on a locksmith and drill out the door locks so I can replace with ones bought online. Can anyone direct me to the right spot to drill to hit the springs in the cylinder?
RobbieD
2.9l Mafia
4,063
Georgia
Just go inside the door and remove the retaining clip to remove the cylinder.
ericbphoto
Overlander in development
TRS 25th Anniversary
18,333
Wellford, SC
6"
Drilling is the hard way and wont get the job done. And you still have to remove the door card to uninstall the lock.
19Walt93
4,723
Canaan,NH
351
3"
235/55R16
/\ Like they said, if you drill it you'll make a lot more work for yourself.
20karatferret
Norfolk va
Ford ranger
I have tried pulling them out but I don't think they can be removed unless the door lock is unlocked
20karatferret
Norfolk va
Ford ranger
I haven't had any luck with taking it out with the cylinder still locked. Is there an easy way to take it off?
lil_Blue_Ford
Cut & Weld
7,070
Butler, PA, USSA
5.0l
4”
You should actually be able to see the tab for that clip on the door. Need to pop the rod off the end of the lock cylinder and then you pry that clip out and locked or unlocked, the cylinder will fall out
superj
3,326
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
the clip looks like a flatish horse shoe. its kind of wavy so it applies pressure against the lock and doesn;t easily pop out. that is why you use the screw driver as a lever and pop it out.
jballard81
270
North Carolina
Just like superj said. mine were stuck pretty solid. vice grips on the clip and a hammer to the vice grips eventually got them out. put a little grease on before re-installing for the next guy (probably still you lol)
TexasDuck66
July Truck of The Month
25th Anniversary Merch
