2.3L ('02-'11) Mystery vacuum leak or something...
PetroleumJunkie412
2.9 Mafia
3,843
Pittsburgh, PA
2.9l Trinity
That ported vacuum hook up would be for some specific reason and only on the 2.3l Duratec because haven't ever seen that type of thing on any other vehicle
.....I thought my 2011 has it as well.... ill check tomorrow.
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
Dirtman
I pooped in the furnace
EMT / Paramedic
5,890
Over there --->
466.63 teaspoons.
So friggin big!
RUM HAM!!!
Took it apart one last time. Went over the intake with a fine tooth come, sealed the crap out of everything. New oring on the map sensor, epoxied the suspect nipple 100% shut from inside out, new gaskets again, tested the egr tube and tightened the crap out of it, cleaned the head mating surface again... I mean there is no freaking way this thing can leak now.
Waiting on a new IAC gasket then going to reassemble tomorrow and hook absolutely no vacuum components up. Plug the evap line, brake booster line, pcv, fresh air to the pcv, EVERYTHING! then run the engine, see if its running correct and start attaching vacuum components one at a time and watch what happens.
If this fails I quit. Trucks for sale.
Well-known member
1,788
LOL, you could be on to something with the smaller vacuum lines
ericbphoto
Old Redneck just wingin' it.
Forum Moderator
2,656
Wellford, SC
6"
Its a 2.3l 4cyl?, so a little light for your predilection to 2.9l V6 boat anchors :)
Sorry, couldn't resist
Yeah. But he’ll find some combination of Ford, cosworth, rousch, shelby, bmw, mercedes, kia parts to get 739 hp out of it.
Dirtman
EMT / Paramedic
5,890
Over there --->
466.63 teaspoons.
So friggin big!
RUM HAM!!!
2.3 duratec makes more power than a 2.9... just pointing that out...
2,496
I've actually considered the 2.3 as my next swap for exactly that reason. More power, less weight, takes up less room.
The stupid EGR placement is one thing that's making my think twice about it.
Well-known member
1,788
It was made for transverse mounting so EGR placement was not an issue :)
Or that back of the head cooling hose
FWD Ranger?
Dirtman
EMT / Paramedic
5,890
Over there --->
466.63 teaspoons.
So friggin big!
RUM HAM!!!
Speaking of the EGR...its one of the things i just looked closely at for a possible vac leak. Im still baffled how it works, the EGR tube runs from the intake to the block but the valve is at the back of the engine. Can't access it without removing the trans but the port runs through the block on the drivers side. Its fully electronic stepper motor so no vacuum lines to the valve itself but if the tube leaks its a vac leak. Also coolant lines back there that cant be fixed without pulling the trans. It has issues with maintenance but the duratec is a proven amazingly reliable motor. Its in everything, including the new rangers. The 2.3 EcoBoost is just a turbo duratec.
Id take a duratec over any factory ranger engine. Even the 4.0 sohc aint much more power, is heavier, and has more maintenance problems.
Im not talking about @PetroleumJunkie412 building his crazy 2.9, im just talking stock ranger engine options.
Dirtman
EMT / Paramedic
5,890
Over there --->
466.63 teaspoons.
So friggin big!
RUM HAM!!!
I did a leak down test of the manifold while I have it off and sealed up. I duck taped over the EGR port and lower runners and then farted down the throttle body port. Couldn't smell any leaks. :dunno:
PUT THAT IN YOUR SHOP MANUAL FORD!
Dirtman
EMT / Paramedic
5,890
Over there --->
466.63 teaspoons.
So friggin big!
RUM HAM!!!
Fixed! I think... computers "disired idle RPM" and "actual idle RPM" now match. Unplugging the IAC now causes the RPMs to drop about 150-200 rpms and fuel trims are re-learning. Long term at idle is already down from +15.6 to +9.3 and still adjusting.
snoranger
Forum Moderator
ASE Certified Tech
3,117
Jackson, NJ
'79,'94,'02,'17
All Fords
So the fart test worked? Good job.
PetroleumJunkie412
2.9 Mafia
3,843
Pittsburgh, PA
2.9l Trinity
DAMNIT. I wanted a 2.3DT with 4wd....
