2.3L ('83-'97) Mystery sensor
DandysRanger
13
North of Atlanta
2.3 FI
If you didn't build it; it's not really yours
Can anyone identify this sensor? It screws into a pocket in the intake but is not exposed to any vacuum or water. I can't find the part number in the Google machine. This is on a 1985 F.I. 2.3L
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
the big flat mating surface is usually a knock sensor.
that's my guess and I'm not going to admit to anything.
ericbphoto
Overlander in development
16,594
Wellford, SC
6"
That's just about the only sensor that doesn't touch coolant, air or oil.
8,370
I would also guess Knock Sensor
What color are the two wires?
Yellow/red was Knock Sensor
DandysRanger
13
North of Atlanta
2.3 FI
The two wires are Green and Black w/white stripe
8,370
Black/white stripe was common ground for most sensors pre-1990
Solid Green could be knock sensor as I don't see that color used on any other sensor, it would go to pin 23 on computer
It also looks like older Ford Knock sensor: https://m.media-amazon.com/images/I/41soHgAzLiL._SX425_.jpg
old part number was E3AZ-12A699-A 1983 number
Later part number F0TZ-12A699-A 1990 number
DandysRanger
13
North of Atlanta
2.3 FI
Thanks, RonD. That looks like it.
8,370
You can test knock sensor with engine running
Use a metal tool and tap any metal part of running engine, RPM should react with each "tap" depending on the part of engine being "tapped" needs to be a good sharp "tap"
