Mystery Engine Block Sensor
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
While tearing down my spare 2.8, I came across an engine sensor that I cannot identify. On the driver's side of the engine, just above where the oil pan bolts up, there are two sensors; the oil pressure sending unit is located just below the fuel pump & engine mount. The other is about 2/3 of the way back, towards the firewall, below Cylinder #5. It's on an extension (like the oil pressure sending unit). It doesn't seem to have access to any fluids (oil or water) as there's no hole in the block, or in the extension or in the sending unit.
Any ideas?
I can provide a picture of the broken sender, if no one has any idea to what I'm referring.
TIA
Uncle Gump
Token Old Guy
13,423
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Knock Sensor
8,369
My turn................................Knock Sensor :)
superj
2,555
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
or maybe a sensor for knock?
Ranger850
Doesn't get Sarcasm . . .
4,680
Tallahassee Florida
Stock 2"
Stock
Knock Knock,
who's there?
Sensor.
Sensor who?
