My Small Block Chevy Swap
RockLobster01
Salisbury, NC
355 CI
hahaaa, nice brinker. well, I just bought a gtech, you should see if you can find one on craigslist or ebay and do some testing. they're not 100% accurate im sure, but if you could get a consistant hp # you could test it with and without the huge spacer? it definatly add plenum volume, but will it or how much power would it make would be interesting. snoranger know it probably wont compete with my 3.0L, but it might come close!
Never thought about that, great idea. I'll do some looking. I may have a buddy that has one. Now that you've given the suggestion, I'm really curious :D
alwaysFlOoReD
5,031
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
No, no, no....no kicking the junk this time! Think about it, the 'right' answer is circled....ie; ford.
Richard
RockLobster01
Salisbury, NC
355 CI
what's the idle rpm?
what's the vacuum reading at idle?
I've gotta do some carb tuning tonight I'll get you these numbers in a few hours. Working on putting a set of spring-lox in to try to eliminate the positive camber. Yes the shocks are shot. Any recommendations? I have a set of Edelbrock IAS shocks in the back.
alwaysFlOoReD
5,031
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I got the same reaction as you the first time I read it too.
Richard
RockLobster01
Salisbury, NC
355 CI
Apparently when the old shocks have up on the front, the I-beams hit my oil pan, dropping the beams now and getting out the BJ Weld....I mean JB Weld
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Um...shocks dont hold up your suspension. Your coil springs do.
RockLobster01
Salisbury, NC
355 CI
I'm putting a set of spring-lox in to correct the issue
snoranger
Professional money waster
ASE Certified Tech
13,527
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
RockLobster01
Salisbury, NC
355 CI
Understood. As the truck sits, I have quite a bit of clearance between the oil pan and the I-beam. Apparently when my shocks gave out, they allowed the sprigs to compress more than they normally did. This was my thinking behind the issue. But I suppose saggy coil springs could also contribute.
I guess I'll try adjusting the sprig-lox to get the desired ride height to correct the camber then try to get a new set of springs that match the height set by my setup? Am I thinking this through correctly?
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
get a set of coil spacers or leveling coils.
RockLobster01
Salisbury, NC
355 CI
Meant to post a pic of what I have
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
That's just a bandaid. You need to CORRECT the problem, not HIDE it. I have a set of leveling coils Im selling for $75.00 shipped. PM me if you want them.
RockLobster01
Salisbury, NC
355 CI
Do you have any photos of what you have?
Kirby N.
March Truck of The Month
