My newest acquisition
Mutant Pony
9
Hersey, Mi
2300
I saved this from the crusher.
That's my '87 in the background
Kinda funny; it has superlift on the rear quarters and skyjacker on the front
suspension.
The stacked blocks, cobbled rear springs and cobbled spring blocks in the front are among the first things to go.
I haven't decided what to do with it though.
Any thoughts?
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
YIKES! does it run/move? whats it got in it?
compleckz
Western Mass
thats a pretty scary truck! does it have any drive train mods?
good find either way!
Mutant Pony
9
Hersey, Mi
2300
No drivetrain. The interior is trashed. The usual bundle of wires hanging from the empty radio opening. It has a small rust hole in the cab. Oh, my least favorite part, A sheetmetal back window!
koda6966
61
The green part of NY.
I'm scratching my head looking at that last picture.
11
mini monster truck??? its what id do since the suspension is garb, and theres no drivetrain.
Mutant Pony
9
Hersey, Mi
2300
Do you mean the fact that it has all that lift and a 7.5?
Or the plastic inner fender pulled loose and laying on the tire?
koda6966
61
I didn't even notice the fender, haha.
Mostly, the blocks look scary as hell.
danger88ranger
ohio
Well, atleast yank everything off and spray it something other than that ugly rust/orange color that the suspension parts currently are sporting.
Mutant Pony
9
Hersey, Mi
2300
Ah! the rear end has been replaced recently, you can see in the picture two different brake hoses. One connected to the truck. one connected to the rear end. There is gonna be different gears front and rear. There is also some white fluid running out the drivers side axle, the front gears are probably junk.
dogboy
14
Enumclaw/ Carbonado, WA
'93
That is an interesting coil spacer, haha.
The suspension is just alll around scary...
I bet the axle wrap is horrible...
I think after you removed all the scary suspension, it would be almost a stock Ranger agian....
cr_the_machinist
Dexter, Michigan
4.0L OHV
I like the the stacked blocks on the rear axle.... hahahahaha. Like thats not illeagal in Michigan... NOT!!!
Motoranger489
Pull all that shit out from under it and throw it up on rockwells, hack the fenders. Whatever tires you can find and wheel it! If you cant afford rocks, a 14bff+60 combo would suffice.
