Now now fellas, don’t scare the man!!
From all the pictures you sent before and now, it’s obvious to me that the front half has been there for dozens and dozens of years, and the addition has also been there a long time. To me it looks like the addition foundation preparation was not as good as it could be. Now having said that, the stairstep cracks diagonally up the block are not that big a deal. If those buildings have been sitting there for decades, And that’s all the cracking you have, that’s not bad. If you had a serious foundation problem, those cracks would be big enough for you to put your fist through them. It’s very common in residential masonry and I wouldn’t lose any sleep over it.
What you have to look for is down along the floor. You’re looking for horizontal cracks in the blocks or in the first level above the floor in the mortar. If you find any, are they on the inside and on the outside, and is one of those cracks much wider than the other crack. That would be the indication that the wall is tilting. That is still completely manageable, but you may want to temporary support the walls as I described before when you pull the roof off.
The other thing you want to look for is cracks in the floor on the inside, but specifically cracks that run along the wall where the foundation may have cracked and the wall is tilting out. All concrete will crack, and diagonal cracks or cracks across the floor are no big deal. But if you have a crack that runs along the wall, again, you could probably figure out if the wall would be tilting in or tilting out. But it’s still not that big a deal, it’s just something you have to be aware of and manage it when you do your remodel.
While I’m thinking about it, if you do any kind of addition that butts up against the existing slab, get a hammer drill and drill about 18 inches laterally into the side of the existing slab every so many feet (I’ll know the distance when we know the plan) and have that rebar extend into the new slab pour. That will keep the slabs level if there’s any settlement in either foundation.
The stairstep cracks could also be a result of the foundation not being deep enough, not being below the frost line. So when you get extreme cold and the water freezes in the soil, it can push the floor up a little or actually tilt the wall a little. But if it hasn’t fallen down in all this time, if you’re careful, you shouldn’t have any worries.
And things like no header over the door, that just goes on the list of things to do when you buy materials and you actually do the work. Are there headers above the double doors on the alley side? Are there headers above the window and the door on the street side? Again, easy to fix, and actually fix correctly, when you do the rest of the work.
@jimoaks ,
I know I’m a broken record, but get me/us Pictures and ask us questions, but I would say focus your energy on how you would want it laid out, without worrying about the cost of this or the cost of that, or how it will get done. Figure out what you really want, and then I and a few of the guys can get the best low-cost design and methods to buy the materials and get it done without having a heart attack.
If you do go steel, I’d avoid the tubing and go with the I-member steel. If you want doors or windows or fans or whatever, you just have to make sure they’re included in the design before they order the steel.
Finally, you are doing the exact right thing in talking to many people about many options. The more you learn and the more things get wild the more what you want to do makes sense.
Don’t get overwhelmed, this is a piece of cake no matter which option you pick.
