I don't know if I need a structural engineer or what.
Remember that gap on the side of the building I filled with mortar? The building is separating here.
I checked it because I noticed the mortar filler cracking on the opposite side of the building.
I don't know what to do at this point other than filling the cracks. I don't know if I could anchor these two walls together with some metal and bolts, or what it's going to take.
It's a cinderblock building with a cinderblock addition added on to double it's length.
Is the crack where the addition was added? Maybe post a picture of the whole side of the building and indicate where the crack is.
Having said that, I’m guessing your frost line is about 12 inches like Atlanta. If they didn’t prepare the soil under the addition properly, and they didn’t put the footings down about 18 inches, it’s possible that just from changes in moisture in the soil (no rain or a lot of rain), you can get an uplifting or settling of the dirt under the building, especially if there’s a lot of organic content in the soil. If it’s just a slab with a turned down edge, and they didn’t remove the topsoil and replace it with clean fill, this will happen every time.
From everything I’ve heard, I don’t think you have any structural problem, certainly not anything worth the expense of digging it all up. Trying to attach the two halves of the wall together would never work. If you think about it, each end of the building is probably a several tons. If they are levering relative to each other, there is no plate or bolt or system you could put in that would hold half the building up or down. You would most likely just move the crack over.
Hence, in my opinion, it’s a cosmetic issue and not a structural issue. I would just get a very good quality caulk, and caulk the crack, and see if the caulk stays in place.
If the caulk pulls lose, and the crack is vertical from top to bottom (vs stepping with the blocks), you could simply hide it with a piece of trim, like a 1 x 4 or a 1x6. If you do that, when you put it up to hide the crack, only attach it to one side of the crack. It would be like an expansion joint on a bridge. If you’re worried about moisture getting in, just put some weatherstripping on the back of the board. It will rub as the building moves, but it’ll keep 99% of the rain out.
My house has a 19 foot tall living room, most of the ceiling being at a 45° angle, with a couple of dormers that face the street. So that roof panel is about 25 x 15 (I’m guessing), and it’s only made of two by sixes, no truss or rafters. It’s a giant sail that moves in the wind. After the house was built (actually modified, I added the second floor), I would get a crack where the ceiling met the side wall, down the angle of that roof, and about a foot down to the window, where it joined the wall. I had the painters dig out about a quarter inch, put a really thick layer of quality caulk in there, and it hasn’t cracked since. That’s probably 20 years ago. I hope I didn’t just jinx myself. Nobody ever notice is it, but nobody ever noticed the crack except me anyway.
As always, my two cents, I hope it helps
