My New House & Workshop
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,631
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You've lost way more marbles then two...
I have a couple old tube socks and an old coffee can full of old marbles. Those were the days....
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,852
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
It's not that I lost them...
It's that they were taken from me.
And crushed.
At least these two are intact.
ElectraRider
107
Colorado Springs Co.
Ford ,Ford
2.9 ,4.0
In Colorado we bury our water lines 6 foot deep man yours is a piece cake.
Jim Oaks
Administrator
Supporting Vendor
8,852
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Ya, I love Colorado. Beautiful state. But that right there tells you how cold it gets.
So today didn't go as planned.
I took some last minutes measurements at the water meter before I took anything apart.
The threads just to that nut are 1-1/4", so I orded a 1-1/4" FIP fitting that had a 1" MIP end.
Wrong.
That new fitting has an inside nut diameter of 1-1/2".
Went to Ace Hardware and looked at fittings, and realized a 1" brass fitting has a 1-1/4" threaded FIP diameter.
Had to drive 45 minutes to Home Depot in Wichita Falls to get a 1" FIP X 3/4" MIP meter adapter, and then a 3/4" FIP to 3/4" PEX adapter.
This makes way more sense than the 1-1/4" to 1" fitting that I then had to reduce to 3/4".
The first fitting and adapter is at the top. The fitting and adapter I just bought is at the bottom.
I'm pretty confident that I have the right fitting now. I'm glad I re-checked thos before I took everything apart and started assembling the new line.
franklin2
1,779
Virginia
The part in the red circle does look like a valve without a handle like someone else mentioned. I suppose the check in the 3/4 line is to keep your water out of the city water system. Like a back flow preventer.
scotts90ranger
4,551
Dayton Oregon
2.3 Turbo
I was kinda questioning your measurements on that fitting, glad you double chedked and it all worked out!
Pipe fitting math is roughly like lumber math, take the measurements with a grain of salt, chuck the tape measure at your neighbor, measure again, subtract 1/73rd of a squirrel and you're pretty close :). I'm WAY more comfortable with metal math than lumber math (when a 2x4 is 1 1/2" by 3 1/5 plus or minus 1/8" and when building a building it should be within like 3" of square or whatever it gets confusing...).
Yeah, I like Oregon too, the depths are fairly reasonable... I cheated when I buried the power for the garage next to the sidewalk where I just went one trenching shovel deep but it's 6" from the sidewalk so the chances of hitting it are very slim...
Roert42
5,080
Kintersville, PA
Ranger XLT
4.0 SOHC
When I ran the power for my garage I used conduit instead of direct burial cable because I only need to go down 18” instead of 24”.
Spent more time with the pick, spike, axe, chainsaw, than I did with a shovel. Took two of us about 20 hours to dig 20’ feet.
then after we finished the trench, but before we could lay the conduit, it rained really hard and we had to spend half a day digging it back out.
Jim Oaks
Administrator
Supporting Vendor
8,852
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I was kinda questioning your measurements on that fitting, glad you double checked and it all worked out!
Hey if you guys see me post something that doesn't sound right, please feel free to let me know. If I had started ripping out this waterline and not caught that first, I'd probably be without water tonight.
Jim Oaks
Administrator
Supporting Vendor
8,852
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
When it rains it pours.
It stormed yesterday and now my waterline is under water. I'm probably not going to be able to start replacing it until Monday. 😒
ericbphoto
Overlander in development
16,796
Wellford, SC
6"
If you really want to, you can do most of the work above ground and just drop it in the trench after all the joints are sealed. I use sticks, 2x4's and shovel handles across the ditch to keep everything high. Then just pull the supports out and let drop in. Works great with PVC.
Junk Collector
Truck of Month
4,873
Rapid City SD
How ironic!
Can you suck the water out with a shop vac? Or a pump if you have one?
sgtsandman
Aircraft Fuel Tank Diver
12,883
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
A cheap sump pump might work. The water looks clean enough to get away with it.
Jim Oaks
Administrator
Supporting Vendor
8,852
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Started the day assembling this section. It's the flow check valve and shutoff valves for the shop and the house.
Trying to run this 3/4" PEX was a ton of laughs. There's an old gas line that crosses here and I had to run the PEX under it and then down to the meter. The PEX wanted to stay coiled up.
Once I got this section ran, I ran 1" PVC pipe over it to protect it.
The water is back on to the house. So far no leaks. Tomorrow I'll run the line to the shop. Then I need to add the spigot coming out of the ground to the right of that valve in the picture.
Still alot of work to go, but I'm happy I was able to get the old line out and the water back on to the house.
ericbphoto
16,796
Wellford, SC
6"
snoranger
Professional money waster
ASE Certified Tech
13,746
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I came across a solution to the “it’s too hard to dig a hole” issues posted earlier…
