jon440x
- Aug 23, 2007
- 0
- Age
- 42
- Mazda
I have a 94 b 3000 4x4 . On the passanger side where the manifold connects to the y pipe .......... is there suposed to be sealent between the two flanges that bolt together ?
My cab is filling with exhaust and i dont realy like it. the exhaust was falling off my truck for a while only held on by the last hangger and the y pipe where it bolts onto the manifolds. till the passanger y pipe came apart from the manifold. so i fixed all the hangers and put a split flange on the y pipe and stuck some bolts in it and called it done
i am hopping that i need to put sealent in the join and it will fix the leak. i hope i do not need to replace the gasket on the manifold and the motor. if it was leaking there wouldnt you see blowby ?
the thing is i do not see where it is leaking from ugh
