Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I have seen a few consoles but not many in good shape...the flares are really hard to find...I really like your flairs you don't see those around.I like your console too went to the junk yard looking for seats and didn't see any consoles like that.It would be nice to have a way to hold a drink.
Thanks! I have an explorer 8.8 waiting till I figure what gears to run...also have a 35 diff for the front...that way I can just pull the third member and swap it out after the gear changeLooks good, keep up the good work. Next is an 8.8 rear diff and the list never ends or you don't have the Bronco 2 fever.
my tires rubbed before i did the cutout flares, even with the body lift...i think i could remove the body lift now and still clear them with the cutouts. it helped me to go to 8 inch rims, my tens really pushed them out there.When I put long arms on it felt better right away too.ľm going to need tires this year I was wondering if your 35s rub on the inside of the tire. I'm lower than you though. Do you know your wheel offset?I like your flairs more but Jim has access to rubber ones that will work good for my set up.
i thought about 5.13s but i dont think i can get them for the front d35...i have a 8.8 ill be putting in and i think they are available for that...is that what you are running???5.13's with those 35's will work great for you. If you have stock 4.10's now, thats what the gear calculator will tell you also.
4.88's are good for 32-33's and the 5.13's work well for the 35's.
not sure of the exact question....i dont have a radius arm crossmember anymore....do you mean the transmission crossmember maybe? i had to cut the crap out of it to fit the radius arm mounts...im getting ready to make a new transmission crossmember this weekendDo you have pics of how you did the radius arm crossmember? I'm considering the same thing..
cool...i just started looking around for gears....do all ifs dana 35s have the same amount of axle splines?? i have an explorer front carrier i want to put the gears in and then swap it with my ranger d35 oneThere are 5.13's for the d35. I own a set.
This, I'm wondering how it'd all go together.. (Like what angle and location the radius arm mounts end up relative to the frame.) Please take lots of pics if you have time.im getting ready to make a new transmission crossmember this weekend
I'll try to get more pics upThis, I'm wondering how it'd all go together.. (Like what angle and location the radius arm mounts end up relative to the frame.) Please take lots of pics if you have time.
