Another half day + of solid work today, felt like I actually made some progress after discovering my A/C manifold mistake yesterday...
Before getting into that, I forgot to mention that I decided to finish on a strong note last night and wanted to get the new tank and l/p pump/sender installed, throw some gas in and see if my hard work paid off.
Since my inner filler/fuel line had significantly deteriorated I ordered some 1-inch fuel to replace it. I got the tank in position and plugged in the wiring harness before raising it into position...NOW I understand why so many people cut out a trap door!
It's not too late I may still do it but MAN what a pain in the arse getting the fuel lines on and clipped in. I had a new vent and gasket and ended up zip tying the hard vent line instead of futzing with a hose clamp, which would have been near impossible. I got the top end of the filler hose exactly positioned where it was previously...which left the tank end quite a bit short with the hose not even reaching the top of the tank filler neck. I ended up splitting the difference and got it firmly in position on both the tank filler neck and up by the fuel door but it was quite a show. I ended up throwing a 5-gallon jerry can in because I didn't want to full tank in case there were any problems and it kept puking gas back at me, but the jerry can's nozzle was pretty janky so I tried a Roto-Pax can with a couple of gallons and it wasn't a problem. I won't know if the line is kinked or there's another problem until I take it to get filled up but that's gonna be a while so I decided to test fire it up...
I primed the fuel system by key on/off a few times and I could hear the pump (in the tank) spinning up each time. I was actually quite audible, much more so than previously but the entire interior is gutted so it didn't bother me. Moment of truth and and it fired right up and quickly settled into a smooth 850 +/- RPM idle pretty quickly. I'm still a lil nervous about maybe needing to drop the tank again and address the filler line and inner fuel hose but for now it's fine. Fuel gauge was now properly working and was reading accurately around 1/4 tank...
So today I decided to install my manifold-less compressor and properly wire in my e-fan. With the exception of a power wire issue that was quickly remedied the e-fan was humming along and working fine, the rat's nest of wires now gone along with upgrading the power/ground wires with 10 gauge wire to handle the 30A.
Although I never knew what an A/C orifice tube was prior to completely redoing my system, I do now and MAN am I glad I changed it out. From the looks of it it was likely the original and while you can make out the metal shavings still on it a whole bunch more slid out of the tube along with it and fell off the tube while I was handling it. With a new accumulator, compressor, condenser and lines it's cheap insurance while you're at it to change it out. The only thing that bummed me out was the "high ambient temp" rated orifice tube would NOT fit, even after trimming off the installation tabs as directed. What chapped my arse about that was it was both a 4Seasons line and orifice tube so using different manufacturers wasn't the issue. Fortunately the rebuild kit I ordered had a new one so I used that...
