Peter Griffin
- Jan 30, 2023
- 362
- Quahog
- Ford Bronco II
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
Got my MONSTER axle nut socket, 2 5/16ths and 1/2 to 3/4 drive connector so I could get the driver's side off, and the weight/heft of the socket and breaker bar were enough to get it started without putting practically any weight on it, whatsoever...
Got the bearings replaced and everything put back together and got if off the stands/lift for the first time in at least a month, if not longer. I wanted to take it for a very quick, very slow/easy test drive and see how everything was working.
The engine seemed down on power and was almost "tractoring"/"dieseling"...like when a plug wire comes off. No backfiring or anything but it definitely was running better before. I checked key on/engine off and engine running codes and had a 22, which I do not believe I've had before.
Looks like all my vacuum lines are good from what I can see, but maybe all the futzing around threw something out of whack. The MAP sensor is inexpensive enough, but I'd hate to replace it if I'm missing something that's a free/easy fix, so any suggestions are appreciated!
On a side but related note it "handled" night and day different. I didn't exceed 40 but there's no doubt the new bushings, body lift/mounts and suspension have made a HUGE difference. It's massively out of alignment right now from the looks of it as I expected, but I was gonna wait to get it aligned once I have the new wheels/tires on...
