And time for an update... Been a busy couple of days.
Got delayed by a radiator leak. Filled it up and it started leaking from a small nick in one of the tubes. Drained it, pulled it, took it to the local shop and $55 later, all fixed and pressure tested to 20#. Got it installed and no leaks now.
Got the ORIs all cleaned up and replaced the lower fluid to spec. Had to replace a couple of the schrader valves because I left the caps off and they got knocked over by my knucklehead dog.... Guess I'm really the knucklehead there.... Anyway, ORIs installed, then charged. Front/Rear got 90# in the bottom, fronts got 400# in the top, rears got 200# to get to the correct ride height. I'm sure I'll have to add more to the rear once I get the spare, fuel, tools, etc... in place.
Ride height good. Measured everything to make sure it would all clear. 114" wheelbase, 19.5" clearance under the belly, 77" at the top of the roll bar, sitting on the 40" old school MT/Rs.
Then on to the brake system... Checked all of the brake lines, tightened up where needed and bench-bled the master cylinder. Then gravity bled all of the lines. No issues with the back, but the fronts were not interested.... So I made up a quick tool, drilled/tapped a flat piece of 1/4" steel and put a schrader valve in it. Added a few #s of air pressure from a bicycle pump (same trick works pretty well if you have a hydraulic clutch that doesn't want to bleed. Add a valve to a spare cap). That got it going... So brakes should be fairly easy to bleed once rolling.
Went through the PS system and tightened all those parts up, then added fluid. I'm sure it'll need more once I start it, but a good start.
Pulled the distributor out and primed the oil pump and let it roll for a bit to make sure the oil was in all the bearings. Then pulled all of the spark plugs out and cranked the engine over several times. Batteries worked great, but more importantly, it didn't puke anything out of the cylinders or blow a gasket/bend valves. It's been a couple years since this engine has run, seemed good prophylaxis...
So it's almost there, at least very close to inital start/run. Have to check the fuel system, add fuel, program the EEC and connect a couple of wires......
Fingers crossed....
Joe
