- Jan 24, 2018
- 4,658
- Tallahassee Florida
- Ford
- Engine Size
- Born with a 3.0, looking for a donor V8
- 2WD / 4WD
- 2WD
- Total Lift
- Stock 2"
- Tire Size
- Stock
- My credo
- Doing things wrong, until I get it right.
Didn't do the tie rod ends, waiting to get more parts. BUT, I did take out the explorer console that was in there and put in an actual Nissan console. It came out of a much newer truck and the rear bracket is supposed to attach to a small airbag computer that I do not have. So i had to fab up a bracket.
I started with a 4" piece of 2x3 aluminum angle
And two 5" peices of 1" aluminum square tube
I marked and pre-drilled the angle to go here
Like this
In the above picture, you can see the square tube attached to the angle. I used self tapping tek screws from the bottom, you could weld it.
Like this
