My 44 Knuckle Swap 35/44 Hybrid
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
I like it. Thought it would stick out more with those spacers. Whats the offset on the rims?
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
The weight of a v-8 should fix that problem!!!!! Jking. Looks great, how does she drive so far?
disciplerocks
53
Evansville, IN
You get that other beam moved?
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
7
murphy north carolina
2.8 v6
I don't know really . But I have new 35's on it locked front and back , so I'll let you know . The 1.5" spacers on the front should be a good test for the wheel bearings .
ok well run it hard and let me kno if u have any problems lol
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
Well I put in some 2.75 degree bushing but that leaned the tires in 3 degrees . So I put the 0's back in and Dustin and I lowered the beam pivot bolts to the lower hole . Now the left tire is in 1.5 and the right is in a little under 3 . But right side is sitting .5" lower than the left and the front looks like it's 1-1.5 lower than the back . So I might lift and level the front a little . What do you think ?
Plus it is towed in about 1" right now .
disciplerocks
53
Evansville, IN
If you add spacers under your coils, it will start to move the tires back out.
Or you could order some 3 degree bushings lol.
disciplerocks
53
Evansville, IN
I talked him into some work then I cut out lol. Sorry man, had to for the woman.
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
Both you guys took off on me . Jon even borrowed tools before he left . Tires look good by the way .
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
same here :thefinger: wife said i had a little over an hour to do whatever i wanted...10 minutes out of the truck and she said come pick me up..
thanks again, we'll see if i cant ruin some bald tires lol. the truck looks damn good on all 4's
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
While making a sharp turn the brake line at the caliper hit the shock . Why don't these trucks have a split system ? I had to drive it home with no brakes not even the back .
disciplerocks
53
Evansville, IN
Damn. Looks like what happened to me outside of Madisonville coming from TB. I had to remove the tee on mine so I only had the front drivers side working, but it got me home.
You get your alignment figured out?
