- Mar 24, 2014
- 3
- NW Iowa
- Ford
- Engine Type
- V8
- Engine Size
- 2.5 to 4.6 3v
- 2WD / 4WD
- 2WD
- Total Drop
- 2/3
The fuel system for the truck starting at the tank is a warblo 225 lph pump. I had to modify the fuel pick up a little to get it to fit. Then while i was in there i had to cut the line for the factory in take fuel pressure regulator. If you don't do this your fuel pressure will be stuck at 70 psi. (ask me how i found out)
Moving forward out of the tank I used the two factory lines that would connect to the duel in, single out factory filter that comes on the pickups. I removed that filter and replaced it with a factory filter, that came on the older style trucks that had a return style fuel system. From there it got a little interesting. I used a combination of factory lines and fitting ends to get me to where i have the an lines. Looking back on it i think it would have been easier to just run the an lines at least back to the filter. O well live and learn.
The an lines carry the fuel up into the engine bay where the connect to a Aeromotive 13129 fuel pressure regulator. Then from there it goes into the factory 4.6 mustang fuel rail.
