Nezorf
- Feb 7, 2012
- Reaction score
- 0
- Location
- San Diego, CA
- Make / Model
- Ford
- Engine Size
- 2.3
- Manual
My 1996 Mazda B2300 2.3L Manual Repair Thread. Current Issue: Temp Gauge
I thought I would start a thread for questions about my truck but also as a subsequent diary/walkthrough.
My background:
The Story:
I just recently bought a 1996 Mazda B2300 (2.3L manual transmission, 203K miles) off of craigslist for $350. The previous owner said that he had owned it for a while and the clutch went out. He brought it to the dealer and they said that his master or slave cylinder went out (he conveniently couldn't remember). I bought it anyway as I need a truck, and $350 is hard to pass by. I got it home by starting it it in first, and speed shifting home. The previous owner said that he replaced the clutch 60k miles ago.
Summary: [updated 4/9/12]
Problems:
-Clutch had zero pressure. Hit the floor and did nothing to the engine. (FIXED)
-Leaking coolant out of the Heater Core Valve (FIXED)
-Dead Temperature Gauge
-Busted up front grill and bumper
-Picky as hell door locks
-No license plate lights
FIRST PROBLEM:
Clutch!
What I have done so far:
What it does now:
What I think is wrong and what I'm planning
My questions:
My background:
- Ex-Motorcycle mechanic
- Basic car maintenance know how (oil changes, brakes, etc)
- General tinkerer
- Minneapolis, MN with a partially insulated garage
The Story:
Problems:
FIRST PROBLEM:
Clutch!
- I tried to do some bleeding in the truck and did not work.
- Disconnected and removed the master cylinder assembly as per the excellent youtube videos
- Bench bled it, and got plenty of pressure.
- Reinstalled in and bled the slave cylindar.
- Closed the slave bleeder and pressed on the pedal only to have the master cylinder break and spray brake fluid everywhere.
- Purchased a new master cylinder from O'reilly auto
- Bench bled the new master
- Installed the new master cylinder
What it does now:
- If I open the slave cylinder bleeder, the pedal loosens up and I can pump plenty of fluid through the cylinder.
- Once the bleeder is closed, the pedal becomes rock solid.
- I have tried pumping the pedal but no change.
- I have redone the quick-connect multiple times to ensure that it is seated properly.
- I've read TRS - Slave Cylinder Stuck?? and I'm assuming I have the same problem
- Purchasing a new slave cylinder and planning on pulling the transmission
- Bought a new Haynes manual and should see it on thursday.
- I'm planning on taking plenty of photos and posting them here for reference
My questions:
- Am I on the right track?
- Any input?
- Is there anything that I should change in my process while I'm in there?
