Mustang 2.3 & T5 tranny
chilsam
chillicothe il
91 branger
300 six
Lucked out and a friend GAVE me a 87 2.3 with 5 speed ranger,his brother swapped in a 87 mustang 2.3 with a T5 transmission. I have to figure out witch system to use the mustangs bell housing is mechanical only should I fab up a bracket for a "hyd" slave cyl or adapt the mustangs mech "cable" pedal an such? Has any 1 done this ? Are there other solutions? It also looks like the alt & power steering bracket will hit the steering box the oil pan looks good tho. Any advice would be deeply appreciated.THANX!! :icon_welder:
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
First question is............What is it going in? Year? I know you said it has a steering box so I assume it is a ranger but tell us. If it is going in a ranger then I wouold hunt the local junkyards (God knows Peoria has plenty of them) and find the correct brackets for the truck. As for the cable operated clutch linkage you should be able to find a setup for an external slave. I think there is a hydraulic setup for a t-5 but I don't remember which vehicle uses it.
chilsam
chillicothe il
91 branger
300 six
Thanx 4 responding both vehicles are 87 the mustang motor and tranny are sitting in the ranger now only the motor mounts are bolted.I think the turbo coupe t-bird uses the external slave cyl but the mustang bell housing lacks the mount casting.I was HOPING another member had dealt with this b4 and could advise me on what he had done "fab a bracket,after market or adapted one from another vehicle".I was also wondering if I could use the mustang pedal,cable adjuster & cable on the ranger. What do you think? I kinda figured I'd have to get the ranger accessory bracket.This truck is in GREAT shape for being 24 years old.
chilsam
chillicothe il
91 branger
300 six
Bellhousings
Does any1 know if I could switch the bell housings & throwout bearings? Bell housing & throw out bearing from the TK-5 to the T-5? THANX!
wlabrum
Riverton iowa
undermined as yet
I looked at doing this same swap using a 88 stang motor and spent many hours doing the research and here is what I found
no the cable system will not work without a lot of mods
the tk5 and the t5 have different mountings centers for trans
if you use a bell housing from a Thunderbird turbo coupe it will hook up to stock master using the turbo coupes external slave cylinder
If you want to get fancy the stock stang uses a bell crank on the bell housing which enables you to use a pull-type(attwood) slave cylinder
I found quite a few t/c bell housings on ebay for less than 100 bucks shipped.
you will probably have to use the ranger alt/ps/ brackets as the stang ones come real close to hitting the steering box
Have fun
BTW I have seen a homemade bracket that bolts to stang bell housing but I did not like the fact that it sits on the same torque plain as the trans as this method reduces the structural integrity
chilsam
chillicothe il
91 branger
300 six
THAAANK-YOU!!! Update found on 1 e-bay THANX 4 your help!!:icon_welder: Also picked up alt and power steering pump with brkt at at Darst street parts for $20.00!.
