Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
That sounds better, I was horrified to read 1 1/2 turns. Maybe 1/6 of a turn, unless there's looseness in the pinion now.Ok, I appreciate the input. I’ll go in small increments and test it. Masking tape around the socket and marked 1/24 increments.
LOL, i had to go check and make sure i put the / in the right place. I wont go any more than 1/12 at a time (half a flat on the nut if that makes sense). If i went 1 1/2, i’d deserve what i got for sure. Appreciate you watching out.That sounds better, I was horrified to read 1 1/2 turns. Maybe 1/6 of a turn, unless there's looseness in the pinion now.
Should be 16-28 in/lbs on new bearings or 8-14 in/lbs on used bearings.If you have a torque wrench with the proper range in inch pounds, I would recommend using one of those to measure your preload as you go.
I thought about that. If i could of bought an in/lb locally, i would have. My ft/lb torque wrench wouldnt click on its lowest setting, wheels and all. Technically what your saying may not be correct but as long as your comparing apples to apples, i don’t see the problem.OK so I'll ask the dumb question.....
What would it hurt to take the axleshafts out of the carrier (to reduce drag) and measure the existing torque needed to turn the pinion? Then use that figure to reset it? You'd have the drag of both the pinion and the main bearings, but as long as the total number remained the same, shouldn't the pinion bearing preload end up the same?
Thats kinda what 19walt93 said. When you say “within the backlash“, i assume you mean the few degrees of play between the pinion and ring gears. I dont see how an actual reading on a torque wrench is possible in that small of a space. Judge by feel maybe. Maybe i misunderstood.The preload checks I’ve seen done were from the pinion nut. There should be enough movement with the backlash to be able to get a reading.
You are looking for a certain amount of resistance before the pinion turns. If it turns before the required torque range, it’s too loose and needs tightened more. You need that resistance met before the pinion turns and touches the ring gear.Thats kinda what 19walt93 said. When you say “within the backlash“, i assume you mean the few degrees of play between the pinion and ring gears. I don’t see how that’s near enough to tell anything, at least not for me. Now for someone thats been doing it for 30 yrs, it may well be. Either you two are the Jedi Masters of preload or i’m misunderstanding something.
You should actually be measuring the the amount of torque to keep the pinion turning. Not the amount it takes to start turning the pinion.You are looking for a certain amount of resistance before the pinion turns. If it turns before the required torque range, it’s too loose and needs tightened more. You need that resistance met before the pinion turns and touches the ring gear.
Starting torque would be higher than rolling torque but within the range. Aim for the high end of the torque range and it will put you within the range for rolling torque.You should actually be measuring the the amount of torque to keep the pinion turning. Not the amount it takes to start turning the pinion.
