Lil'Red1997
- Dec 6, 2019
- Reaction score
- 2
- Location
- Kansas City
- Make / Model
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- Manual
- 2WD / 4WD
- 2WD
I have a '97 2.3L manual transmission ranger with multiple issues. I'm hoping you guys can help me come up with some things to check.
1. Super slippy clutch cooled off for 2ish hours and now it's back to normal
I got my oil changed today at a tire place that was advertising oil changes for $24.99 (that ended up nearly $40). I know, I know, I should have changed it myself. Now, I have had a new clutch on the "to do" list for a while because the clutch will slip in 5th when trying to accelerate up hill, down shift to 4th and it's fine. When I picked the truck up, it was slipping a bit in 1st. The more I drove it the more it slipped. Eventually I got stuck going up a hill. I inched my way back down the hill on the shoulder and into a parking lot. My dad came to rescue me and helped me complete my time sensitive errands. We returned to the truck about 2 hours later and it was fine. I drove all the way home no slipping or struggling like it never had an issue. Back to "normal."
2. Lugging/no power under 2500 rpm "takes off" over 2500 rpm.
Any gear under 2500 rpm the truck lugs and chugs and crawls along no matter how hard you push the gas pedal. Once we inch up to 2500 rpm it just "takes off" almost like if you started puttering along with the parking brake on only to release it. That's just an analogy. It is not the parking brake.
3. Rev hang/creep
This has happened several times in the short 3000 miles I've had the truck. Coming up to a stop, pushing the clutch pedal and/or in neutral the rpm has stayed high, 2-3000 rpm, for 5-10 seconds. Once it even crept up from idle at a stop to about 3000 rpm where it stayed for 10-15 seconds before dropping back to idle.
4. Leaking power steering
The power steering leaks ALL OVER. I have removed all the nasty old black ATF that I could with a turkey baster, maybe 4-5 oz? I then refilled it with ATF safe power steering stop leak. It still leaks.
5. Check engine code P1443
This one is intermittent. I can make 4-5 trips without the CEL coming on or it will come on with every erase/start up cycle. I have not noticed any pattern and it seems to run the same no matter what.
5. General sluggishness
This truck makes my Prius C feel fast and trust me it's no race car.
6. Hard starting after short stop.
This has happened twice, both on warm days. The first time I stopped at a gas station just long enough to go walk in see that they were out of what I was looking for and get back in the truck. The second time I filled up with gas and jumped back in. Both times it went like this: Crank crank crank fire stumble die. Crank crank crank nothing. Wait 5ish minutes crank while pumping the throttle started up and drove away. Both times my wife was with me and now she thinks it is an unreliable piece of junk.
3. Rev hang/creep
