Move fusebox aside to reach clutch master cylinder?
fixizin
FoMoCo is forcing me to buy a 'yota
20
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Seems I saw a video "somewhere", eons ago, where you could detach the underhood fusebox, and there was enough slack in the wiring harness to move it well away from the left fender, and thereby have MUCH greater access to the clutch master cylinder... what's the trick, where's the hold-down?
Thanks in advance.
Rock Auto 5% Discount Code: DE2235E7692E8C: July 5th, 2021
ericbphoto
Overlander in development
Forum Moderator
5,642
Wellford, SC
6"
On my 93, the fuse/relay panel just snaps onto a metal bracket. Just pry the tabs a little bit to release them from the brackets.
I would recommend disconnecting the battery as a safety precautions first.
fixizin
20
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
I'll check it out... Good tip about the battery, thx...
