More terminology
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I had a lady say her car was making a strange noise. I asked if she could elaborate exactly where its coming from, when it happens etc. She said it constant as soon as she gets in the car it beeps. I said is the dome light on or any doors not fully shut? She said the doors are closed and the light is off. So she brought it over. I get in and sure enough it beeps every 20 seconds or so.
I took the cell phone out of the glovebox and handed it to her...
ericbphoto
Overlander in development
16,350
Wellford, SC
6"
Yes, RED doors or bed is mostly RED so really helps to avoid break downs
RED hood helps the most, better airflow over all with a RED hood
What if I put the red in the inside?
Inside the transmission
Inside bearings and bushings
Plus I like to use red wire
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Yeah. Wait. Glyptal paint is red. So red does make gofasts...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
We're all red on the inside.
8,298
Well the science just shows RED on the outside of vehicles/Rangers helps the most
But couldn't hurt to make the insides RED, but that's more aesthetics than science
And...................."A pints a pound the world around"
19Walt93
4,412
Canaan,NH
351
3"
235/55R16
Only question that needs to be asked is........."What color is the car/truck?"
If the answer is not RED then you found the problem
Simple solution, paint it RED, then it will run fine....................forever
Now that's science
All Rangers are RED, any other color is just primed waiting for the final coat of RED
So if yours is not RED then it wasn't finished at the factory, try to get your money back :) or paint it RED yourself
And its why Rangers last longer, its because they were all build like a RED vehicle, but without that final coat you can have break downs
Its a Starter "Relay", not solenoid, a starter solenoid is on the starter motor it moves the starter gear in and out, thats what solenoids do they MOVE things, a Relay activates electrical circuits
They are Core Plugs, not Freeze Plugs
Actually on an older Ford the solenoid is on the fender and it sends power to energize the field coils which pull a metal weight down and forces the starter drive out so it meshes with the ring gear. Old guys(older than me) will often call the starter drive a bendix. They both drive the ring gear but they're far from the same thing, a bendix is spinning when it hits the gear and a starter drive engages the gear before the starter spins.
sgtsandman
Aircraft Fuel Tank Diver
12,390
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
In New England a grinder and a sub are the same thing.
Around here, an oven toasted hoagie is a grinder. If it isn't toasted, it's just a sub or a hoagie.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Pennsylvania is a strange strange place...
sgtsandman
12,390
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
No,I'm not going to lecture again about calling Supercabs "extended cabs" or traction lok's "posi's" though it's still happening.
Saying it doesn't run, shift, stop, or work properly won't help anyone diagnose a problem. There are people here who will try to help you given a chance and enough info.
I used to insist my service advisors ask the customers questions that would give the techs useful information:
"Hesitating" means that there is a delay between throttle movement and rpm increase
"skipping or missing" mean that the engine shudders or shakes and is usually more noticeable when the engine is under load
"surging" is when the rpms vary and is often noticed at idle and when trying to maintain a steady low speed
What driving conditions make the problem worse or more severe? High speeds? Low speeds? Uphill? on turns? On bumps? Engine warm or cold? Outside temp? Accelerating?
Are there driving conditions that make the problem less noticeable?
How long has the problem existed and did it happen all at once or gradually worsen?
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
What else is he hiding in that soap box ??? Looks big enough to hide 1/2 dozen rolls of TP !
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Ranger850
Doesn't get Sarcasm . . .
4,664
Tallahassee Florida
Stock 2"
Stock
My old 83 Ranger had a bendix on it. I rebuilt that thing twice before I finally got a new on.
My buddies and i have also bendix for a whule now.😉
Kirby N.
March Truck of The Month
