Mitsubishi FM145 teardown video
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
Junk Collector
Forum Moderator
2,310
Rapid City SD
Hope he does a reassembly video... everything in there basically applies to the FM-146 and FM-132 as well.
Paulos
204
North Carolina
1987 STX
I wish he had been a bit more detailed in the reassembly, but it's enough to encourage me to experiment with one of the worn out FM145's I have. I notice now that there are bearings and races inside the gears on the main shaft that are not included in the rebuild kits. I would think that those need to be replaced also, but buying them separately looks like they would be expensive.
franklin2
646
Virginia
I suppose if he was clairvoyant and knew the only problem was that large bearing in the front, he could have pulled that bearing out, drove another one in and be good to go. I believe that is the one he had problems getting out and had to pull it from the front anyway.
