Mitsubishi FM145 swap help
cybertechit
New member
Ohio
2.9
Hello, I am new to these forums. I have a 1988 Ranger 4X4 with a Mitsubishi FM145. It has went completely out, so I am going to get a new one to put in it. What I was wondering is if the Mazda M50D-R1 would fit with not to much trouble? My 1988 Ranger is a 4X4, will the transfer case fit (electronic)?
Thank you
Paul
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
11
Salem, IN
Yes the M50D-R1 from any 4.0 will fit on your 2.9 engine (the '86+ Rangers and BII's have the 2.9 and FM-146, not the 2.8 and FM-145). It is a direct swap. The transfer case will bolt onto and work perfectly as normal. You will have to use a 4.0 clutch, flywheel, and starter. You will have to run a trigger wire down to the 4.0 starter and do a little wire changing on the stock starter solenoid for the 4.0 starter to work.
I just swapped in a M50D-R1 in place of my A4LD in my BII. Went off without a hitch and works perfectly.
When you do this, let me know if you have any questions.
cybertechit
New member
Ohio
2.9
Thank you, I will keep you posted on this.
Totalled
New member
Law Enforcement
Tumwater, Wa
8 rabid gophers
85-87 would be FM145, 88-90ish should be an FM146, which is the same length as an A4LD/M5OD. So, it might require a clutch line change, but is otherwise pretty much a bolt in.
Hahnsb2
New member
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
^True story^
I'm almost 100% positive the slaves between the 146 and the M5OD interchange, I recall the same part numbers for the slave in my dads M5OD and my 146 so clutch line should be fine.
Jspafford
Logan Andrew Feb 17, 2012
13
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
^True story^
When I did my swap, I pulled the slave off the FM-146 and it fit right onto the M5OD.
MAKG
New member
18
California central coast
That all may be true, but given all the effort for a transmission swap, I'd suggest a brand new clutch and slave to go with it, unless they are in perfect shape.
Hahnsb2
New member
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Yeah definitely, I'm saying he can use a slave that should work with his current clutch line.
werewolf
Odessa Texas
2002 & 1999 & 1
4.0&3.0&2.9&351c
take life day by day
anyone know where i can find shifter parts for my Fm145. have tried Green parts & tb trans. no luck, out of stock. thanks nice web site you have here.
needhelp101
New member
New to this, I am attempting to do a a4ld to a fm145 manual, pedals and everything went smooth, now im stuck. i have the slave cylinder that comes out the top of bell housing. but when i try putting the housing on, the slave hits the front retainer plate and holds the housing about 1/2'' away from trans. Anyone ran into this problem before? help please...
2,387
jimbott388592
New member
blytheville arkansas
ranger stx 4x4
30 x 9.5-15 achilles desert hawk
whats a good swap for a trashed fm145 in a 1987 stx 4x4 2.9
Junk Collector
Forum Moderator
567
Rapid City SD
M5OD, search the forum for info on this, it is a very common swap and well documented here.
