- Jun 2, 2012
- Reaction score
- 8,370
- Location
- canada
- Make / Model
- Ford
- Manual
Yes, with MAF unplugged computer switches to Open Loop so no longer does the air/fuel calculations, and ignores O2 sensors, just runs engine on Factory tables for that engine size, same as it does when engine is cold
With engine warmed up and idling
Unplug the 2 wire connector on the IAC Valve
Idle should drop to 500-600rpms(barely running) or stall, either is GOOD it means no vacuum leaks
If idle doesn't change then there is a leak
