- Jan 13, 2019
- 806
- Pennsylvania
- Ford
- Engine Type
- 3.0 V6
- Engine Size
- 3.0
- 2WD / 4WD
- 2WD
- My credo
- My world is filled with stuff that needs to be fixed
We had another round or torrential rains and flooding here in PA, and the drive home was rough. I went through one particular deep spot not far from home, and although I went slowly after I got out I could feel a misfire. Shortly after I had a flashing CEL and it barely ran (probably in limp-home mode). I pulled over as soon as I could find a spot, and it had a P0303 (#3 misfire).
There was no obvious water in the engine compartment - everything looked dry. I limped it very slowly another mile to a parking lot, and tried to see what was up. The misfire was persistent, and as the weather was horrid I limped it the 2mil to home on back roads. On the way down hill it smoothed out and the CEL light went off, but when I loaded it again it came back.
After I dragged our lane I pulled the plug on #3, which looked fine, cleaned it and put it back. Sprayed the coil pack and wires with brake clean. Fired it up and got a P0303 and a P0316 (misfire in first 1000 revs). If I reset them and let it idle it's OK and the CEL is off with no pending codes. If I take it out and load it the misfire comes right back with the P0303.
Any ideas? I thought of water getting in the fuel but only #3 is misfiring. I'm worried the head got shock cooled and cracked, but the engine compartment was dry. I'm sure water could have splashed up from below, but it seems like it should take more than that.
