Minor Fuel Line Leak.
Blacksmith1
Volusia County, Florida
Ford/Explorer
Its spurting a bit from a return line on the frame, aft of the fuel filter. Is there a way to safely patch this plastic line?
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Cigarette lighter and some electrical tape.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Junk Collector
Truck of Month
4,797
Rapid City SD
You can get patch kits for these at most parts stores. However. Since it's just the return line, and is not pressurized, I have replaced that whole section with rubber hose in the past. Steel brake line is another option. Rubber is not ideal but hey, if it's not leaking and not in danger of leaks since it's not under pressure, it'll get you by.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Quicker for sure... better, that depends on what you're looking for as an end result. lol
3.0 truck
Just... just let it die
Blacksmith1
Ford/Explorer
Its a 96 with close to a quater million miles on it. Just need it to run a bit longer
MXGerry
21
You can get patch kits for these at most parts stores. However. Since it's just the return line and is not pressurized, I have replaced that whole section with rubber hose in the past. Steel brake line is another option. Rubber is not ideal but hey, if it's not leaking and not in danger of leaks since it's not under pressure, it'll get you by.
My uncle got this Ranger with a fuel leak. The previous owner suspected it was the return line. We're going to take a closer look after we finish installing the suspension from 4Wheelonline onto Wrangler and clear the garage. We may opt for a steel brake line if ever.
