Mild Clicking on Deceleration
8thTon
--- Banned ---
806
Pennsylvania
When pulling to a stop I hear a mild click, which is obviously at driveshaft speed. It's not loud, and it never does it with any power applied, but if I'm out of the throttle I can hear it. Is this likely to be the pinion bearing or just wear on the gear faces?
Uncle Gump
Token Old Guy
13,159
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Any kind of vibration in either loaded or coasting?
If you suspect rear end... I would pop the cover off and take a solid look around.
8thTon
--- Banned ---
806
Pennsylvania
No, it's smooth and makes no vibrations or other rear-end-failing kinds of sounds. I topped off the fluid a few weeks ago - it was a pint or so low - and the fluid that was in there seemed pretty clean (I pulled some out just to see).
Uncle Gump
Token Old Guy
13,159
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just know most times with rear end issues there is a hum... whine... howl and also some sort of vibration. Not always... but...
Is this an open rear end or a trac lok?
8thTon
--- Banned ---
806
Pennsylvania
Yeah, there's no whine or howl like what I'd expect, which is why I'm curious. With an offset hypoid gear the forces on the gears are rather different when the pinion is driving the ring gear vs. the other way around.
It's an open diff 8.8 with a 4.10 gear.
sgtsandman
Aircraft Fuel Tank Diver
12,386
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
U-joints going bad?
8thTon
--- Banned ---
806
Pennsylvania
U-joints going bad?
Oh, yeah, I forgot to mention that. U joints was my first guess too, but they feel fine. I jacked up the rear and spun the shaft - there was no play or slop, or anything that seemed wrong with them. Hardly a definitive test but I really don't think it's the U joints.
17,513
SW Iowa
Best way to test u-joints is to remove each end from the truck and actually feel how things move.
If they don't have grease zerks... there is a good chance they are original.
8thTon
--- Banned ---
806
Pennsylvania
I have read that this type of noise (pinion speed, only on deceleration) can be a chip on defect on a face of a pinion tooth. However, I've noticed that the noise is simply not there when it's cold and only shows up after driving some distance. When the snow goes away enough to work in the driveway I'm going to pull the cover and see what's going on, and refill with thicker gear oil.
cbxer55
763
Midwest City, Oklahoma
I run 75W-140 in all my Fords. My Lightning takes it, and I always have it in the grudge, so I sue it in everything, even my shaft driven motorcycle.
Eddo Rogue
2,472
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Maybe its just your teeth?
8thTon
--- Banned ---
806
Pennsylvania
But I brush daily?
Eddo Rogue
2,472
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Kirby N.
March Truck of The Month
