Mercon vs. Mercon V??
Jason_J
5
Tacoma, WA
Somewhere there is a FSB that says Merc V should be used instead of Dex/Merc. My manual calls for Mercon in the Manual trans, transfer case and power steering pump. Is it safe to assume that Dex/Merc is fine as long as it's not mixed with Merc V?
Thanks,
J
Earl43P
38
Farmington, Pa
Ford F250 4WD
MerconV is synthetic.
It's better in every possible way, for each component you listed.
I use it to quiet noisy Ford Power steering pumps. Almost miraculous, the difference it makes.
I also put it in my old 2000 4wd trans/tcase/ps pump.
I put synthetic gear oil in the differentials (you have to suck it out of the front axle).
Synthetic lubes are simply better, hands down.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Mercon V is not necessarily synthetic, in fact most of the time it's merely a synthetic blend. You can mix the two just fine, nothing bad will happen. You can continue using regular Mercon or use Mercon V, it doesn't really matter.
Earl43P
38
Farmington, Pa
Ford F250 4WD
^^I'm glad you posted that; I assumed that MerconV specified synthetic base.
I stand corrected. It can any of the GroupII or GroupII plus oils.
Ford has specified MerconV for at least the last 8 years of production.
Most of the aftermarket MerconV you find on the shelf will be at least partial synthetic.
Some good reading here: http://www.ford-trucks.com/forums/114482-base-oil-technology-group-i-iv-what-it-all-means.html?fb_xd_fragment#?=&cb=f358bfa6271581e&relation=parent&transport=fragment&frame=f23fabaa6b878f
Jason_J
5
Tacoma, WA
Cool, thanks guys!!
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I wouldn't be so fast to assume Mercon V is always better.
There have been several reports of Mercon V causing poor shifting in earlier M5ODs. I suspect it may be too slippery for the M5OD's synchros to function properly.
Personally I would stick with plain Mercon (Dex/Merc nowadays) in the M5OD, and use the Mercon V everywhere else (T-case, power steering).
Earl43P
38
Farmington, Pa
Ford F250 4WD
No members online now.
