Mazda b2500 not charging
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
ive replaced the alternator, checked mega fuse, dont know what else to do
Ranger850
Doesn't get Sarcasm . . .
4,684
Tallahassee Florida
Stock 2"
Stock
Test the battery, check cables at both ends for corrosion. Most people only check the battery end of the cables, but I have seen the other ends get so bad that the battery would not charge.
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
ive done that, and ive replaced the battery. still no luck
Ranger850
4,684
Tallahassee Florida
Stock 2"
Stock
did you replace both cables too, from block to battery and battery to starter?
have you had the starter tested?
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
yes. and no i havent. but as long as the battery is hot the truck will start and run
Ranger850
4,684
Tallahassee Florida
Stock 2"
Stock
:huh:Is it the correct sized battery? does the battery have water in it? it should. This is a real head scratchero_O
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
yes its the right size. I had my dad check the water in it. its got water. ive been stumped for awhile
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Did you buy a reman alternator from a autozone, advanced, or similar discount chain store? If so... Mystery solved.
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
yes. but when i put the alternator on my dads ranger, it charges his truck. so im still stumped
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
So I am stumped
Ranger850
4,684
Tallahassee Florida
Stock 2"
Stock
So I am stumped
I would go get a brand new alternator and try that if it works take the other one back, if not take the more expensive one back and try something else. If you have a good battery, good alternator, and good cables, and everything is hooked up like it is supposed to be, and it still wont charge, you have a "ghost in the machine"(anime) type situation
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
my truck has over 300,000 miles on it and it just started recently
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
its been my dads daily driver for over 5 years and mine for 2. i just need it running again.
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
ive put a brand new one and a reman on and it still does the same thing
turiforzan09
heflin, al
RANGER
2.3 L4 OHC
how would i deal with a "ghost in the machine"
