Material to use for touch up below window?
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
973
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
There is a strip of, looks like galvanized, metal below the front door windows, the black on it is mostly gone, on the flat part, it looks odd, I want to put it black again. They used some kind of sort of rubberized paint. Because where it is missing is at least a straight line to where it isn't, the fix shouldn't be that hard, and it doesn't have to even be perfect, but I want to put something on there. I'm thinking gloss black (for instance Rustoleum) wouldn't be quite right, it's more of a flat finish, and I'm wondering if anyone has any ideas what would work well there. You almost could put black tape on it. I just want something that matches fairly decently, then it wouldn't stand out like it does, cosmetically. Sure would appreciate any hints or anyone who has had to do this.
66132
Milkman5687
30
North florida
Ford ranger
I used rustoleum 2x semi gloss black. Looks pretty good, just masked off around it and sprayed very light coats till it was painted completely
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Plasti-dip would be the closest thing to the factory finish.
James Morse
973
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
CrabGuy
474
Sacramento, CA/Seal Rock, OR
2004-Bone stock
Ranger XLT
Why should I pay someone else to screw it up when I can screw it up myself for free?
I did mine and decided against the Plasti-dip stuff since the whole concept of peel-off later wasn't a requirement. Bare aluminum needs a good bond under any coating. The Plasti-Dip wont bond as well as a good rattle can with a built in etching primer. I used this stuff, it worked out well and matches the OE pretty well.
James Morse
973
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
Wow, that looks fantastic! Thanks! What color is the textured Rustoleum, is it black or more or a grey?
Yes the peel-off feature isn't really desirable, the OEM stuff peels off and that's the whole issue.
CrabGuy
474
2004-Bone stock
Ranger XLT
It was black, not gray.
RangerVet
34
Kingman, AZ
FordRanger Edge
From here on down it's uphill all the way!
Kind of an old post for an answer but I used black carbon fiber tape from Autozone. It went on easy and I trimmed it with a sharp razor blade. Black 2005 2 door.
