Factory hubs were made by Warn. Factory hubs are what’s on most of my trucks. If your front axle is stock, it will be a Dana-28 (12 bolts hold the pumpkin to the axle beam when viewed from the front). Your options for that are pretty much Factory or Warn. I may have a set around here somewhere, if I think about it when it stops raining I’ll try looking around. The hub itself gets changed along with the spindle nuts for the bearings. You could also source a set from a junkyard. Bronco II and Ranger are fair game as long as the axle is the same as yours.
If you have a D-35 front (think 1990 was the first year for those) it will be a 10 bolt holding the pumpkin to the axle beam when viewed from the front, you can use Factory, Warn, or Warn hubs for a Jeep D-35 which are a little stronger than the normal hubs. The axle shafts are thicker than the D-28, so you have to get the correct hubs for your axle. Hybrid front axles (3.0l trucks) have D-35 everything except the smooth pumpkin has D-28 inners and the shafts are necked down where they go in the pumpkin. So the hubs on those are D-35. Most 1990 Bronco II, 4.0l Rangers and all Explorers until they went IFS used the D-35. Somewhere mid 90s they went to D-35 for all Rangers, not exactly sure when though.
