gtkid2002
- Jul 11, 2014
- 0
- Ford
Hey all. I scored an '83 2.3Lima 4WD a week or so ago. Was told it had a bad HG, but there was ZERO oil/coolant contamination. Oil was just dirty, no shavings from what I could see.
I got the thing running, and it would run at higher rpms (2-4k), but at low rpms it would shudder and buck like crazy. Had decent throttle response, but I never wanted to try and drive it anywhere to load test it. It would start cold, but once it warmed up I couldn't get it to start again unless I held open the choke valve, and even then it was a good 20 seconds of solid cranking to get it close to wanting to go. The carb leaked a little from somewhere on the radiator side. All four plugs were BLACK in under one minute of run time (replaced from stoopid bosch 4 prong plugs, ugh). They were gapped to .44-.45. It didn't seem like it was able to run on all four cylinders properly, so I went with the diagnosis of bad HG between cylinders.
Now I don't have it completely apart yet, and I don't have access to a compression tester. But the exhaust studs are soaking in PB blaster, and I'm gonna go whack them with a hammer, and re-soak before I attempt to remove them.
Read here for actual question:
So what carb can I swap over to? I've got the old round style heated intake manifold, and I'm guessing I should hang onto it since I'm in AK (first year here), so what carb can I bolt on for cheap that'll work decently enough?
I'm not concerned about power much (last rig was a bug), and I do enjoy fuel economy. But budget is my #1 factor (borrowing a rig, I need this one going ASAP).
I want a cheap basic carb that I can slap on to get me by till I can get something better. I want as few lines as possible. I am in the process of learning what lines I can pull, what lines I can't pull, and what EGR lines I'm blocking off since mine has 3 for some reason Any and all help in this situation will be greatly appreciated.
Notice: I'm pulling my EGR systems because they're more than likely not functioning properly, and I do NOT want to mess with it more than I absolutely have to. If I can find a great way to keep it on and simple, I'll be more than happy to keep it on. I'm not going out of my way to try and step on toes, I just need a working truck right now.
