Making a New Gear
oldgeek
1,027
USA
Ranger XLT
I'm designing a new gear. I have it all figured out on making it except one thing. How to put the keyway in the bore. I was going to ask about how to do that, but am not sure how to broach the subject.
8,296
There are a couple of ways
Google: how to cut internal keyways
Using a shaper or lathe is the slowest method, but works just fine, need tool with correct width cutting blade
You can get an attachment for a drill press with correct width grinding blade
So depends on what machining equipment you have access to
alwaysFlOoReD
5,030
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I saw what you did there...
rumblecloud
1,105
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
ericbphoto
Overlander in development
16,346
Wellford, SC
6"
don4331
1,329
Calgary, AB
5.3
You don't need a broach, it just makes the job a lot faster.
I drilled 2 small holes in corners of what would be the keyway corners so that I would have a final reference point; then number of larger holes to remove the majority of the remaining material. A cut with the hacksaw to join the holes and some file work to smooth everything out.
And that's how I broached the subject.
ericbphoto
16,346
Wellford, SC
6"
You, sir, have an enormous amount of patience. Well done.
don4331
1,329
Calgary, AB
5.3
My kids might disagree with that comment.
Some piece of machinery on the neighbour's farm had a lead screw with an unusual pitch (not standard metric or imperial) that failed. He wrapped a silk ribbon on a piece of rod in helix of the correct pitch, scribed that onto the rod and then proceeded to cut the screw with a hacksaw. It was about 3' long; he did it all with 1 blade for the saw, and when he finished it looked better than the factory piece.
When you learn from craftsmen like that, my level was minor.
And what hurt with my project - Blackspire came out with a 38t rear sprocket a couple years later. So, the bike has a commercial gear now, not the fancy one I made.
oldgeek
1,027
USA
Ranger XLT
With a job like that, it would take some ex-splining.
Kirby N.
March Truck of The Month
