Maf sensor problem
Tunnermann
11
Brazil
Ford Ranger XL
Hi there,
The previous owner had a maf sensor from another car installed. It' a 94 4.0 ohv ranger.
It runs on gasoline and on natural gas, similar to glp.
When I run on "Glp" it runs smoothly as it requires less air (it even has a tbi reduction, like a funil {this is normal}).
So now that I want the extra ponies from petrol I realized it's misfiring. Before I open the engine and check the valves, if they are sitting correctly, I wanted to check if there are any AFTERMARKET or a MAF SENSOR FROM ANOTHER CAR that could replace this one. Probably there will be explorers on the list... I can't really find many parts for 94's here in Brazil but there are plenty for 95-97... would they work? I've noticed that the part numbers are almost identical... the only difderence is the end. My maf would be F07F-12B579-A2C.
Any help is appreciated.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I think the last 3 numbers is a revision number. Most likely there is no difference to the running of your engine.
Tunnermann
11
Brazil
Ford Ranger XL
I've also noticed that there are some parts that are instead of F07F, they are F57F... (F07F-12B579)
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
F = 199x. 0 = 0 so 1990
F = 199x. 5 = 5 so 1995
I don't know what the 7 and other F stand for but may be plant where built and type of part.
8,370
F07F
F0 = 1990 as said, or F5 = 1995
7 = Ranger
F = electrical part/department
12B579 = MAF sensor part number, not model specific
As said the number/letters after these are revisions, can matter
Yes, 1994-1997 would work as long as its for a 4.0l engine and 4 wire, 6 wire have a built in air temp sensor
Tunnermann
11
Brazil
Ford Ranger XL
I've got this one right now... F57F-12B579-BA.
Rockauto suggests F07F-12B579-A2C
Could this be responsible for my misfire?
8,370
No
Failing MAF can cause bogging and hesitations but not a steady misfire
Misfires are spark, fuel, or compression
Compression, generally, won't be intermittent as its mechanical, so best to test that first whenever there is a misfire issue
Tunnermann
11
Brazil
Ford Ranger XL
No
There's a constant "little machine gun farts" noise ?. From low the medium range revs its noticeable... maybe it exists in the higher range too, but then I can't hear it.
But now and then it really bogs bad. To solve this I have to clutch and step on the gas until 4-5krpm, then it comes back to "normal"
8,370
Bogging was a common sign on the 4.0l OHV when MAF sensor was dirty or failing, these should be cleaned once a year, its easy to do
Tunnermann
11
Brazil
Ford Ranger XL
I've cleaned it already with rubbing alcohol and a cotton tip... not sure if it's good enough... I've heard it should be cleaned with some eletrical fluid thingy...
