Chris_1
- Feb 1, 2009
- 1
- Ford
Hi guys, got a little problem I could use some input on. - '94 ranger xlt s/cab 4x4 auto; starts great dies in seconds. Unplug the maf starts and idles but won't rev up. Original maf, 1 known to be working used maf and a brand new one - same thing. plugs, wires, fuel pump and fuel filter all newer or new. Fuel pump running when you turn the key. Power at greeen/yellow wire under relay - on at start and run ; power through inertia switch.
I have a full set of known to be working sensors, wiring and pcm, thought I would just start changing things 'till something works - any thoughts on the most likely culprits to start with?
Did just pull the transfer case to clean the governor (1-2 upshift delay when cold, which cleaning the governor fixed) and replaced the fuel pump on Monday, truck worked great till Friday morning when this problem started (or maybe I had an early version of this problem and changed the fuel pump for no reason, but what the heck it's new now).
Going to start randomly changing sensors and such tomorrow, so if anybody has any opinions, I would certainly appreciate your input.
