M5OD-R2 abuse
Daniel Black
44
Leicester, NC
302
205/60R15 & 225/60R15
How much abuse can the R2 take? Specifically one from a '98 F150 with a 4.2 V6. By abuse I mean, wide open, on the floorboard, stab the clutch and bang it through the gears. The more I drive my truck the more I wish I had an overdrive transmission but the R2 is my only option cost wise.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Sub 350 tq?
If it's fresh...it will make some miles.
Anything over 300 tq be smooth.
Daniel Black
44
Leicester, NC
302
Sub 350 tq?
Should be under 350ft lbs. It's just a used transmission with unknown miles. Correction on my part, it's out of an '02 F150 if they're any different.
17,827
SW Iowa
No hole for speedometer drive FWIW. 97 and maybe 98 had the hole but guts inside for a VSS, can be adapted using parts from an older M5OD to run a speedo.
They got better as time went on. I would pop the cover off and check out the innerds though.
Junk Collector
Truck of Month
4,800
Rapid City SD
ZF 5 speed from an early 90's 2wd F250? Kind of a 5 speed school bus trans though if you know what I mean.
Those M5ODs should be fine for your purposes.
Ramcharger90
1,708
N/A na
306, Bcam,
Yeahhhhh I had to put a T5 in my ranger. I had a one of those.... the slave cylinder went out very fast for a brand new one. But with that said that transmission probably wasn't gonna last much longer. It really didnt like shifting fast.... at all.....
Honestly I would have spent the money on a T5 the first time If I wasn't so cheap...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Uhh what do you think the "OD" in M5OD-R2 stands for? :icon_confused:
ericbphoto
Overlander in development
16,593
Wellford, SC
6"
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
M-Mazda
5- 5 speed
O- over
D- drive
R- revision
2- two
but yes. The trans will hold fine. Replace the leaking shifter rail plugs. Run either mercon v fluid. Or synchromesh fluid. And shift it like a truck. She’ll be fine.
After 93- they had no provision for speed sensor. You can swap the tail shaft with a 88-92 model. But you’ll also need the gear. And retaining ball to hold the gear.
I’m going to experiment if you can drill the case for a speed sensor.
Daniel Black
44
Leicester, NC
302
Yes, that's what the OD stands for. The R2 would be my only OD option as far as cost goes. No T5s, TKOs or ZFs or any other OD.
