M5OD-R1 vs. M5OD-R1HD
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The transmission I used on my '97 Ranger came off of rwenzing's '03 Ranger. I think there is no doubt that his truck was a 4.0 SOHC.
I say again, the SOHC bellhousing has one relocated bolt hole
The bolt hole at the 2 O'clock position.
AD
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
AD
I hear what you are saying, but I KNOW that the SOHC bell housing did NOT have an extra bolt hole on my '97 OHV.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
doesn't the r1HD have both bell patterns? I think I read that somewhere ....... and seen a pic..... it may have been at dezert rangerz.
james99
this info should go into the technical libarary when it is all put together
fastpakr
2,832
Roanoke, VA
Maurice - any chance rwenzing's trans had been replaced with a regular M5OD before you got it?
Fx4wannabe01
February 2010 OTOTM Winner
20
Boring, Oregon
2002 M5OD-R1HD....note: a couple of dual holes... Either for both bolt patterns or alignment dowels....
2001 4.0L SOHC:.....Towards the right of the centerline of the block, just under the passenger side head...notice the 'blank' spot? Could that possibly be what's a threaded hole on a OHV?
Hole in question clearly does not have a bolt in it in this pic...
Oh..Maurice...your edited thread over at RF was no help during that auto to manual swap.
mjonesjr
Firefighter
13
Salem, IN
Doubtful. The truck only had like 25,000 miles on it when he took it out.
Should have asked me here. None of my how-to's are there anymore. I don't share my info with people who don't want me around:icon_thumby:
AllanD
TRS Technical Staff
134
1987... sorta
'93 4.0
The trans pictured HAS the "extra hole"
Please note that on the back of the SOHC engine that there is a plug
where the top right bolt goes
Also notice that there is an extra hole <2" away down and further right.
The trans pictured is a "Dual bolt pattern" trans.
You argue against what I said then post pictures to prove my point for me.
Now is the time for me to ask "Are ya stupid or somethin'?"
AD
mjonesjr
Firefighter
13
Salem, IN
You are correct Allan. I apologize. I found a picture of the transmission I used.
swamprat
lexington KY
Just to mess thing up a bit, my 1995 F 150 with an inline 6 has a m5od-hd in it. Also my buddies with a 302 in his f 150.
mjonesjr
Firefighter
13
Salem, IN
Your F-150 has the M50D-R2.
swamprat
lexington KY
My haynes book says different. Chiltons says M5OD-R2. Could that be why I had a hard time finding a seal for the yoke on my 2wd trany?
rboyer
4.hoe
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Doesn't the newer trannies have a different spline count output shaft so the would not mate to old transfer cases?
fastpakr
2,832
Roanoke, VA
All the same.
