M5OD question
Strieg
Central California
2.9
86 4x4 2.9 Have an a4ld now. Want the m5od. The question
Will transfer case bolt up
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Yes it will.
Strieg
Central California
2.9
Ok cool. Here's another straight forward question. And yes I have read through the tech library and posted up another thread but still the question remains.
Will an M5OD replace my A4LD with no problem. Other than the floor pan/shifter plate. It will bolt up fine to engine (2.9) and transfer case (BW1350M) and Everthing else without an fabrication or hassle.
alwaysFlOoReD
5,419
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
OK I'm not a mechanic and this info is from older motors [60's/70's] but should still apply.
There is a bushing/bearing in the crankshaft that will need to be installed for the manual.
You'll have to figure out how you're going to install the clutch pedal, I don't know if you can re-use your original column/pedal support while adding a clutch pedal, you may have to r+r that with one from a rbv that already has a manual trans.
The trans may be a different length, so you may have to lengthen shorten driveshafts and move cross-member.
A little more research is in order!
Good luck,
Richard
4x4junkie
593
So. Calif (SFV)
2.9L V6
35x12.50R15
Pilot bushing goes in the flywheel on a 2.9L.
M5OD and A4LD are both the same length.
There MIGHT be a difference in the t-case shifter between the M5 and A4 if you have a manual case, though I can't recall for sure (if there is, it may be minor enough you could just modify it a bit and get it to work).
TexasDuck66
July Truck of The Month
