M5OD guide
NakedDucks
63
B’ham AL
If I were to write a guide (with pictures) about the M5OD trans...
Other than how to:
-identify which engine one came from
-build,
-what will interchange
-and even how to convert to between 2 and 4 wheel drive versions...
Is there anything else the folks of TRS would like included? I have a lot of the parts (some pretty rare), but may ask for others to be sent to me for photographing and then returned (I will pay shipping both ways....or I may buy them if possible)...
Is this subject even a tech article you’d like to see?
alwaysFlOoReD
5,468
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
I would also be interested in such details. I plan on swaping an m5od in place of my current a4ld at some point in the near future.
Junk Collector
Truck of Month
5,097
Rapid City SD
I am intimately familiar with these things now and would be happy to help with this project if needed. I think it would be a huge benefit to the community.
gaz
706
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
∆ from 2 wheel to 4 wheel drive output.
Junk Collector
Truck of Month
5,097
Rapid City SD
In the grand scheme of things, this is really very easy - you just need your trans, a 4x4 tailhousing, a 4x4 main shaft, an output seal, and main/countershaft nuts. That's assuming you reuse everything inside yours. The part most people get hung up on is that it requires a complete teardown, and more than likely you will find other things to replace at the same time.
PlumCrazy posted a very nice low gear swap writeup a while back - I referred to it the first time I did mine. The factory service manual is pretty decent for rebuilders as well, although it doesn't contain a lot of the technical stuff like the differences between early, mid, mid-late and late model transmissions, bellhousing patterns, gear ratios, stuff like that.
8,397
There are more M5OD-R2 how-tos out there than M5OD-R1s
Would be good to do an R1 and specify its an R1
Also point out that the M5OD transmissions have a one-piece case so are engine specific, R1 or R2
There were 5 R1 engine versions, most came in 2wd and 4wd sub-models, but not all
The 4.0l versions had different 1st, 2nd, and 3rd gear ratios than the 3.0l, 2.9l and 4cyl versions
2.9l/4.0l OHV version 1988-2000 2.9l was only 2wd and then 2wd or 4wd after 1990 with the 4.0l, 2.9l and 4.0l used same block so same bellhousing but different gear ratios
4.0l SOHC HD version(R1HD), 2001-2011 2wd and 4wd, has an extra bolt hole in bellhousing, but still interchangeable with above years, has a different shifter arm than earlier 4.0l version
3.0l Vulcan engine version, 1991-2008 came in 2wd and 4wd
2.3l/2.5l Lima engine version, 1988-2001, came in 2wd, and 4wd but limited after 1997
2.3l DOHC Duratec engine, 2001(mid year) to 2011, only came in 2wd
The 2wd versions lost the tail shaft speed hook up in 1998, as did the 4wd transfer cases
The 2001 - 2011 M5OD-R1s ALL had an OSS speed sensor added, 2wd or 4wd, so 2001-2011 Ranger can ONLY use these years as replacements
1998-2000 Rangers can use the 2001-2011(matching engine) M5R1s since they get speed signal from rear axle ABS sensor
1990-1997 Ranger 4x4 can use any year 4wd transmission, matching engine, if they keep original transfer case, since it has the needed speed signal setup
All the above applies to Mazda B-series 1994 and up
gaz
706
Wa, Bremerton 98310
Shran + RonD
Cool, sounds like my 94 (4.0) M5OD may get to push the Ranger's 2.9L ..)
TexasDuck66
July Truck of The Month
