M50D-R1 speedometer gear
EvanCole45
27
California
Ford Ranger GT
Hey guys, I need to get a remanufactured transmission for my 1988 Ford Ranger GT. I’m wondering if my truck has a 6,7, or 8 tooth speedometer gear. I hope someone can help me out with this.
thanks!
8,369
Manual trans and 4WD transfer case should be 7 tooth drive gear
scotts90ranger
4,359
Dayton Oregon
2.3 Turbo
It's hard to tell, would be easiest to take the speedo gear out (one bolt with 7/16" head I believe) and look in the hole, the different gears are different colors I think white, yellow and red if memory serves.
Junk Collector
Truck of Month
4,791
Rapid City SD
He's got a GT which would be 2wd... does that still ring true in this situation? Been quite a while since I've dealt with a 2wd truck.
8,369
Yes, all Rangers with 2WD manual trans used 7 tooth drive gear, but it could be swapped/removed
2WD Automatics(C3 to 4R55E) used 8 tooth but it was machined onto the tail shaft
4WD transmissions didn't have speedo drive gear, short tail shaft, manual or auto
The transfer case had the speedometer gear, all 7 tooth, and swap-able/removable
1998 and up Rangers started to lose the speedo drive gears, 2WD automatics still had them up to about 2001/2 but no hole in tail shaft housing for the driven gear
2WD manuals didn't have the gear installed or the hole
Around 2001/2 Ford start using an OSS(output shaft speed) sensor on the rear of the transmission, 2WD or 4WD, manual or auto, these used a Tone wheel on the shaft, not a gear
For 4Low the computer would recalculate speed signal sent to speedometer, for the higher Ratio
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The 1350 t-case out of my '90 has a red 6-tooth gear. I think it's only 1354s that have 7-tooth gears.
8,369
Certainly possible, it comes down to axle ratios and tires sizes offered on that year
But if you have to "guess" use 7 tooth with Rangers
Common size Driven gears are 16 to 21 teeth
7 tooth drive with 4.10 ratio and 35" tire uses 16tooth
7 tooth w/3.73 and 27" tires use 21tooth
Osinski91b
Michigan
Does anyone have a part number and an equation for figuring out what tooth number is needed. I have a 1990 ranger 4x4 manual with 285/65R16 tires
8,369
Welcome to TRS :)
You also need your rear axle ratio
Look on drivers door back edge, there will be a label there with vehicle info
Look at the bottom, under AXLE will be a 2 digit code number
Then go here to look it up: https://www.therangerstation.com/tech_library/axle_codes.shtml
Your 285/65R16 tires are 30.6" diameter you need that as well
Then go here: https://www.tciauto.com/speedometer-gear-calculator
Go down to
Speedometer Gear Calculator
You have a 7 tooth DRIVE
Ratio ???
Tire 30.6
It will tell you how many teeth should be on the Driven gear
Osinski91b
Michigan
It is a 3.73 ratio. Sorry I forgot to put that in. Thanks for the info. Still trying to find where I can find a new gear. Anytime I search Google it brings up gears for the t5 transmission
ericbphoto
Overlander in development
16,584
Wellford, SC
3.0L
6"
Last time I needed one, I think I ordered it from Jeff’s Bronco Graveyard.
ericbphoto
16,584
Wellford, SC
3.0L
6"
It’s as if you’re the tooth fairy paying $1 per tooth. I think BG had the best price I found a few years ago.
Osinski91b
Michigan
